Results 1 to 11 of 11
Thread: how much CYA for pool with pool cover
    Apr 2013
    Westside LA, CA
    49
    solid gray automatic pool cover
    mostly shaded when open
    what cya should I aim for?
    32x15 IG Borate+Salt, Pentair VS+SVRS, howard swim pure 40 SWG, Pentair 4000 48sqft DE, Mastertemp 300, Electric Pool Cover, Polaris P93, 4 Kids for Aeration, ;)
    38,305
    Re: how much CYA for pool with pool cover
    30ppm
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    Hi Cloudbusting! How long have you been maintain your pool? You don't have a SWG do you. Have you been having issues with getting chlorine levels to fall?
    I second the recommendation to keep CYA low with your cover. I had mine at the recommended 70 all last year, and it was a real bear to get chlorine levels to drop when they creeped up during my dialing in the SWG phase. I'm leaving mine at 50 this year to see if it is more manageable, but it is proving to be just as difficult.
    I'm actually entertaining the idea of having some Chlorine reducer on hand which is Sodium Thiosulfate .
    18'x43' Sport Pool
    19,000 Gallons Vinyl Liner 3'-3.5'-4'
    SWCG and D.E. Filter
    Test Kits - Pool Calculator - Chlorine/CYA Chart - Pool School
    Secret Weapon for Pool Chemistry Testing
    Apr 2013
    Westside LA, CA
    49
    Just dumped 200pounds of salt into the pool today and getting ready to add ic-40 swg - still recommended to keep cya at 30? Swg school article mentioned 50-70
    38,305
    With a SWG, you likely want to be in the 50-70ppm range. This is slightly lower due to the cover and shade.
    Apr 2013
    Westside LA, CA
    49
    Why 70ppm with swg+covered vs. 30ppm for covered pool and conventional chlorine?
    I thought cya protects clorine from sunlight or does it help the swg also?
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    Quote Originally Posted by Cloudbusting
    I don't know the answer, but suspect the answer is not clear because having and using an opaque cover is not what the majority are doing. Therfore there is not a lot of data on exactly how high it needs to be.... It's much easier to raise CYA if you have problems keeping chlorine in your pool. If I were you I'd start at 30 ppm and see how it goes.
    18'x43' Sport Pool
    Apr 2013
    Westside LA, CA
    49
    should-i-increase-my-cya-levels-t251.html
    Looks it was discussed before... Cya appears to help the cell
    I think I'll aim for 40 initially and see how it goes
    Cover is "solid" gray/no light goes thru it
    38,305
    You can try the CYA at 30ppm. SWG are slow to add FC, thus the need for added protection from the sun. See what the required setting on the SWG to maintain your FC, if the setting is high, you may find that increasing the CYA will actually lower how hard the SWG has to work ... theoretically this should actually make the SWG cell last longer as well.
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    If the pool is mostly shaded when opened, but also closed the majority of the time, how many hours of sunlight per week are we talking about? 4? 8? Seems like your really talking about inside pool conditions. I get full sun on my open pool about 13-15 hours per week, and at 50 ppm CYA if I overshoot FC with my SWG it can take weeks to come down. Just sayin'.
    18'x43' Sport Pool
    Apr 2013
    Westside LA, CA
    49
    About 8h/week of sun
    Swg is starting to feel comfortable at around 40cya
