Thread: Waste returns to pool when filtering to waste
    When set on "waste", some water returns to the pool. I am trying to vacuum after treating with flocculant and this is defeating the purpose of filtering to waste. What is wrong?
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Waste returns to pool when filtering to waste
    Welcome to tfp, Brendazane
    It sounds like your spider gasket may need replacing. Have you taken your valve off and looked at it?
    No, I haven"t done that. Will check it. Thanks!
