Thread: Rust stain
    Oct 2008
    Yuma, AZ
    33
    Rust stain
    I have 2 small brown rust stains on the floor of my in-ground fiberglass pool. How do I get rid of them without draining my pool or destroying the gel?
    14,000gal IG Fiberglass pool with 850 gal spill over spa, Whisper Flo 1hp pool pump, Whisper Flo 2hp spa pump, DE filter, Zodiac Clearwater LM3 SWG, "Heat Siphon" Model SX5HP pool/spa heater, a water leveler and a Kreepy Krauly cleaner
    30,419
    Re: Rust stain
    Crush up some cheap vitamin C tablets, place them in a sock and hold the sock (weight it down) against the stain for about 10 minutes. Longer may be necessary. It may not get it all but it will get a lot of it.
    Oct 2008
    Yuma, AZ
    33
    Re: Rust stain
    Vitamin C "fix" did not work ... did it twice ... once for 30 minutes ... once for 60 minutes. Any other recommendations?
    30,419
    Re: Rust stain
    Pretty good chance it is not rust but also an equally good chance they are permanent.
    I removed a construction nail (probably been there all winter) from the bottom of my vinyl pool and cannot remove the stain with vitamin C. I pretend it's not there.
    You could probably have some affect on it by concentrating some muriatic acid on it but you stand some chance of damage to the liner.....not worth it in my case.
