Results 1 to 8 of 8
Thread: Salt generator - AquaComfort, Hayward, Goldline or Pentair??
    While we are replacing our filter and redoing the plumbing we are considering getting a Salt Generator put in. I have seen a bunch of them (AquaComfort, Hayward, Goldline, etc.). Any difference between these? And do these truyl get rid of the need for chlorine?
    whoozer's Avatar
    Apr 2008
    Acton Maine
    633
    I would do a search on the threads here for SWGS. There is a wealth of info on this site about personal experience with many of these systems. Look under the equipment heading. There is an allocated section just for swgs. That will help you come up with some more specific questions and maybe even help you weed a couple of the systems out
    14x33 fiberglass freeform
    Variable speed Pentair intelliflo superpump
    420 Clean and Clear Plus cartridge filter.
    pool-school/pool_calculator , http://www.tftestkits.net/
    I wouldn't quite say that they eliminate the need for chlorine, but very nearly. If you do get algae, which is less likely with a SWG, you will need to add some chlorine manually. A SWG does save a lot of work however.
    There are a number of excellent brands. I am fond of AutoPilot, which has some features the others don't, but there are many other less expensive choices that are excellent.
    we use Aquacomfort they make a good product
    Ft Lauderdale, Florida
    1,455
    Just a clarification:
    Aquacomfort is a marketing company not a manufacturer. The salt system they sell is a private labeled unit made by Resilience.
    Sean Assam - Sean@teamhorner.com
    National Accounts and Commercial Products Manager
    AquaCal Heat Pumps www.aquacal.com
    AutoPilot Salt Chlorine Generators www.autopilot.com
    Jun 2008
    Chesapeake, VA
    19
    Also Hayward owns Goldline... when I contacted Goldline customer support for some info on a return jet fitting for my Aquatrol, they sent me over to Hayward.
    ~12000 gallon 15x30x4 On-ground Pool
    Aqua-trol SWG
    Polaris 65 Pool Cleaner
    Hayward C500 Cartridge Filter (50 sq ft.)
    Working on being troublefree!
    Re: Salt generator - AquaComfort, Hayward, Goldline or Pentair??
    Quote Originally Posted by DSKNY
    You know, I have not done a lot of research on each of the brands - but I do have the Goldline AquaRite, which was put in when my pool was built and have had that for 2.5 years so I can tell you my experience.
    First of all, I almost never need to add bleach/chlorine and that is a good thing (I add it 2-3 times per year when I want to shock or after a LOT of rain). BUT I do need to keep an eye on the Ph and I have to add acid about once a week to keep the Ph correct and avoid scale build up on the fuel cell. And I have to keep an eye on the salt level. And on the CYA and the alkalinity. I only add salt like once a year when we get a lot of rain and we lose some of the water from it spilling out and kids splashing. That is not a big deal.
    I think you do have to monitor the levels of these things more closely when you have an SWG - but to be honest - I LOVE doing that and have learned so much here to make it all easy. And I like not having to lug and store the big jugs of chlorine and to remember to add those on a regular basis and to know that if I get all the chemicals right I can go away for one or two weeks and not worry. And the kids say they like my pool the best because the water is always so nice and they think the chlorine is not as strong because it is a salt pool. Plus I take care of it myself and I think I spend about $5 per month on chemicals.
    So, would I spend the money on an SWG again? Yes. The system was put in when the pool was new which did help absorb the cost. The builder picked that brand because he said it was the best and the easiest to use and most trouble free.
    Anyway back to the issue of Goldline. I just posted in the SWG section that I had a problem with the LED light not coming on. Turns out the $800 board was shot and this is after 2.5 years. Goldline replaced it for free and it is a much better version according to the pool guy. I did have to pay labor which was $144. But I do have a new board. I was impressed with the customer service from Goldline and for the fact that they do prorate things when they need replaced - they had mentioned that when they thought the board was older than it was or regarding a quote for the fuel cell.
    The only consideration is that the fuel cell will cost around $450 to replace and that can come after 2 years if you allow a lot of scale to build up by not cleaning and not adding acid on a regular basis or about 4 or 5 years if you take care of it and maintain the Ph levels in your pool and shock with liquid bleach/chlorine instead of using the SWG.
    And that is my .02.......
    ____________________
    14K gallon inground pool
    plaster finish
    cartridge filter
    SWG - AquaRite
    Dolphin Diagnostic Robot
    "Having a pool reminds me of having an aquarium when I was a girl - I love taking care of it and testing it - just don't have fish this time around!"
