G
Guest
waterbear said:The chlorine is a consumable so it does get used up. That is why it needs to be put in daily. However, the CYA should not be changing like that. The only thing I can think of is that your pool is cloudy from algae and when you add chlorine it clears it a bit but then it gets cloudy again. The cloudiness is making you think the CYA is higher than it actually is. We need you to describe what your water looks like in addition to posting the numbers. There seems to be a real communication problem going on here. You are just not providing us with the whole picture. You are a hairdresser so you know that you need to communicate with your client when they sit in your chair so you know EXACTLY what they want. If they say cut my hair and make me blond and you give them a heavy frosting and a pixie cut when what they wanted was a deep gold single process and a chin length swingline bob you know they will not be happy so the first thing you do is question them to find out what they really want. This is much the same except YOU are that client that is really not telling us everything. My comment about the time above is to illustrate what I am talking about. I am sure you meant 8:06 but you did not say am or pm (fm is a type of radio) and the o'clock after the time is not needed but it does show the communication breakdown that has been going on since you started this thread.hairco said:It is 8.06 oclock here
What time is that in English please? I don't know what time 8 and 6 hundreths o'clock is! And would that be am, pm, or fm?
and i just did a sample of my pool water
and they have really change again.Is there something growing in my pool
or is it the heat and sun? I am going again to put Muratic acid and bleach in.
FC 1
TC 1
CC 0
pH 7.6
TA 120
CH 30
CYA 100
There is no way your CYA can increase 50 ppm in the course of a few hours! Is your water cloudy at all?
I know my numbers are right.
