Results 1 to 8 of 8
Thread: Bleach Question
    Mar 2013
    CT
    349
    Bleach Question
    How many days per week would one need to add bleach to an in ground pool when following the BBB method...or would this answer be different for every pool and each set of circumstances?
    16 x 32 In-Ground vinyl, 21,000 Gallons, Hayward Cartridge Filter, Hayward Tiger Shark robotic cleaner, Taylor K-2006 Test Kit
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Re: Bleach Question
    In the summer with a good bit of use I add bleach everyday. I test my FC level everyday.
    Jeff
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,995
    Re: Bleach Question
    Quote Originally Posted by dschribs
    Sent from my Samsung Galaxy 10.1 using Tapatalk
    You'll learn your pool's personality soon enough. During swim season, most of us add every day. We might get lazy and skip testing if we've been adding the same amount every day for weeks and just add the usual.
    Host a pool party and you'll be adding 3X a day!
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,600
    Re: Bleach Question
    EVERY--day. I lose 3 to 4 ppm daily.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Re: Bleach Question
    Another good thing to do, and I do it, is to keep a log of everything you do to your pool water. I record all the test results,how much of whatever I add to the water, pool water temp, outside temp, how sunny it was, how much use the pool got that day. You'll start to see trends with your pool.
    Jeff
    Mar 2013
    CT
    349
    Re: Bleach Question
    That's sort of more work than the chorine tab route isn't it? My buddy who has a really nice pool has a chorine tab in line system - not sure of the exact name - and he told me he tests his water once every few days and if the chlorine is low he just turns up the dial on this system and it simply adds more chlorine to the pool.
    Richard320's Avatar
    Jan 2010
    18,995
    Re: Bleach Question
    It also adds more stabilizer. And it doesn't evaporate. I bet your friend also does a weekly shock. That's the pool store way. And when it all builds up so high that none of their expensive treatments will work, they advise a drain because of high Total Dissolved Solids.
    I suggest you read Pool School a little. There are automated systems that can use liquid bleach as well as saltwater generators. Both of them are pretty hands-off. I'm out in the yard pretty much every day anyway so it's no big deal to grab a jug and eyeball a quart of bleach into the pool.
    Mar 2013
    CT
    349
    Re: Bleach Question
    Thanks!!
