Page 1 of 2 12 LastLast
Results 1 to 20 of 21
Thread: Possible suction side air leak?
    Tiny bubbles are coming out of the returns. Is this normal for a SWG?
    Here is a video
    http://youtu.be/StQ7TUk6o2o
    18x36 Grecian Vinyl; 8' Roman steps w/t 2 spa jets; cozy cove w/t 6 spa jets; 2 MD, 1 Skimmer, 3 returns; Hayward Ecostar, 30" Ranger sand filter; Hayward color logic 4.0 LED light; Hayward aqua logic; 2" PVC pipe 4 Jandy Valves
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,023
    Re: Possible suction side air leak?
    Turn the SWG off and see if it stops.
    How long after turning the SWG off should it take if it is the SWG to stop shooting out bubbles?
    Richard320's Avatar
    Jan 2010
    19,023
    Quote Originally Posted by kyle11
    I would imagine no more than a minute. How far is it from the SWG to the return?
    Could this be the culprit?
    http://youtu.be/WOuh0xKjgLs
    Also this is after SWG is off for 2-3 minutes.
    http://youtu.be/bWlaOvMqH1k
    Quote Originally Posted by Richard320
    The closest one is about 20 feet. Farthest one is
    About 50 feet.
    Richard320's Avatar
    Jan 2010
    19,023
    Strainer basket seal is one of the most common sources of suction side leaks. It sure looks like it in the first video. What was I supposed to see in the second?
    I'll copy some of what I posted just a day or two ago, because it's relevant
    [center:2snl290q]Round up the usual suspects: low water level, stuck weir in the skimmer, loose drain plugs on the
    pump, poor seal on the pump strainer basket, and leaks at the fittings, especially any couplings.
    [youtube:2snl290q]vtSmfws0_To[/youtube:2snl290q][/center:2snl290q]
    [center:2cuobpuv]Round up the usual suspects: low water level, stuck weir in the skimmer, loose drain plugs on the
    [youtube:2cuobpuv]vtSmfws0_To[/youtube:2cuobpuv][/center:2cuobpuv]
    Ok I will check those. The 2nd video was shooting bubbles still coming out after SWG was off for a few minutes. I did take the pump top off yesterday. Could be it.
    Richard320's Avatar
    Jan 2010
    19,023
    Auto mechanics rule of thumb: the last thing you worked on is the first thing to break.
    Will any oring lube from a hardware store work ? I have never lubed the lid oring since installing it late last year.
    Richard320's Avatar
    Jan 2010
    19,023
    Silicon based grease. Petroleum greases will cause the rubber to swell. Which is fine while it's together, but the next time you open it, the O-ring will jump out at you like one of those joke snakes in a peanut can and you won;t be able to but it back in.
    Pool stores sell tubes of the stuff, and it's not outrageously overpriced like baking soda.
    Got some pool pump silicone lube. Doesn't seem to help. I can still see very tiny pencil led size bubbles in the pump. Doesn't look like much at all to me. Pump holds prime always and there is never bubbles bigger than that after running it for a few hours. Also still some coming out of the returns. They seem to shoot out in spurts in a way. Like they are exploding out. Could it be to much hydrogen getting built up because of the way I did my salt cell? If I just do a pipe straight down then put the cell parallel to the ground would that make a difference?
    Also I have not cleaned the cell would the affect anything?
    I have checked my jandy valves, they seem find. Might be where the pipe connects to the pump though. I used blue tape as I didn't have any pipe dope left.
    Thanks for the help.
    gtemkin's Avatar
    Jun 2008
    Seattle, WA
    738
    Blue tape? As in blue painters tape? Sorry, that won't do. Pipe sealants and teflon "tape" are homogenous materials that lubricate (prevent galling and stiction in threaded joints) and seal by flowing and filling microscopic leak paths. Although teflon tape is called "tape" it has no adhesive and is made of 100% teflon, a very soft, very slick plastic.
    Blue painters tape contains two layers, one is crepe paper and one is a rubber pressure sensitive adhesive. Neither of those will lubricate or flow or seal very well.
    Suggest you clean those threads up really well - lots of wiping with a rag - and use the right stuff.
    21K gal 16' x 40' in-ground pool built 1959, old school with Jacuzzi bronze pump, American Products 24" Sand Filter & Americana Multiport valve, Jandy Lite2 millivolt heater, Coverstar cover, and classic Kreepy Krauly.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Teflon tape comes in a variety of grades/thickness from the basic thin white, on to blue, pink and yellow (yellow is I think the thickest and rated for gas service) I am not sure about the difference between blue and pink, but blue teflon tape is much thicker than the common white type, but not nearly as thick as yellow.
    Quote Originally Posted by gtemkin
    Lol ya I used the blue Teflon tape. Sorry should have said. Never crossed my mind someone would think I used painters tape but I see where your could. I have just seen where some people has had problem with the Teflon tape on the pump connection.
    gtemkin's Avatar
    Jun 2008
    Seattle, WA
    738
    Whew...my technical faith in humanity has been retrieved. Thanks for confirming.
    May 2013
    Scottsdale, AZ
    37
    Have you bled the line on top of your filter? Sometimes doing that will clear out any bubbles in your filter or infloor system.
    12K play pool, sparkle quartz finish, Compupool salt system, PVC2000 infloor system, Emerson 3/4 filter motor, and AO Smith 1 HP infloor motor, PacFab Challenger Pumps
    Quote Originally Posted by jaimejaime
    I do not have one on my sand filter.
    I have been reading about the ecostar and these small bubbles and it looks like many others have has this problem. My bubbles are very small as can be seen in the linked video below.
    http://youtu.be/zY9zXzBwqvI
    I hold prime at all times and the pump basket is always full. The more I look at it I think it is the SWG.
    I still am looking for a answer on if the way I plumbed the SWG at a 45 degree angle is ok as far as building up hydrogen. My thinking is water at a slower speed could be rushing down at that angle and gravity is creating pockets in which hydrogen is getting trapped which in turn makes bubbles at the returns if you follow what I am saying. I see it like a water slide where the water at slower speeds would just be on the bottom half of the pipe. Maybe I am just fretting over nothing though and off base. I just know it drives me crazy when I see bubbles shooting out and there is really no priming or major bubbles in the pump.
  20. Back To Top    #20
    Here is a line from the installation manual
    "The cell may be mounted vertically or horizontally".
    I don't it at a 45 degree angle. Should I re plumb that part? Or is it ok to so it that way.
