Thread: New pool and Salt just added. Here are my latest results
    FC 4
    pH 7.5
    TA 70
    CH 140
    CYA 40
    Salt level 4000
    Water temp 72
    Water Clarity Clear
    What next?
    McKinney, TX
    Pool build in progress, 14.8K gallons, OK flagstone copping (sealed), IG Gunite/Pebblesheen (Blue Granite), Pentair intelliflow 3050 vs - svrs, Pentair IC20 Salt-Gen, 60 sq ft Pentair DE filter, 400k BTU Pentair (NG) heater, Polaris 280 with Booster, Dual Time Clocks with freeze protect feature, Pool (1) 500w (1) 100W Spa (1) 100w lights, (2) Skimmers, 4 Pool Returns, 6 Spa Jets, water features incl (3) 12 scuppers on 12 x 31 raised beam, (2) Gushers on tanning ledge, and double cut spa spillway. controlled by easytouch 8
    http://www.troublefreepool.com/under...t56120-40.html
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,037
    Re: New pool and Salt just added. Here are my latest results
    Fire up the heater and go swimming.
    You might think about raising the CYA a little to deal with the Texas sun. I would hold off on boosting the CH, because new plaster and evaporation will drive that number up soon enough.
    Thanks Richard. I plan on hitting the spa very soon.
    McKinney, TX
