Results 1 to 8 of 8
Thread: Fountains and what not
    I am looking to add a fountain.. thoughts on these?
    http://www.poolproducts.com/SPP/dept.as ... 622&FNM=99
    Other suggestions?
    Thanks, Justin
    2003 Marquis Euphoria - 400gal
    MikeInTN's Avatar
    Middle Tennessee
    1,335
    Hey Justin,
    Are you looking at a fountain for cooling your pool, for aesthetic reasons, or both? I've got a triple tier fountain that I use in the summer time to help cool the pool when it gets too warm, and it works great. The lighted ones look good on the webpage, but I haven't seen any in person to be able to give a good opinion on those.
    24' x 52" AGP - approx 13,500 gallons
    Pentair Optiflo 1 hp/2sp pump w/ Swimpro Voyager 150 sq ft cartridge filter
    Intex 8110 SWCG
    "Fear the Schnauz!"
    May 2008
    S.C.Myrtle Beach
    47
    Fountain
    Mike can you tell me how your fountain works.Would i have to do some work because my pool is up & running
    I don't think my DH would wount to plumb. So i would have to do it myself.Thanks
    Carolina Girl!
    Pentair 1 1/2 Hp
    Pentair clean & Clear Cartridge filter
    14 x 32 FG inground Pool
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Fountain
    Quote Originally Posted by hairco
    Most fountains have an adapter to mount to a return. No plumbing required.
    My reasons are aesthetic only.
    MikeInTN's Avatar
    Middle Tennessee
    1,335
    Re: Fountain
    John's right on the money - my fountain has an adapter that mounts to my upper return, and then uses a length of clear plastic tubing to go to the fountain. I unscrew the and remove the ring and jet, and then screw the adapter on. The adapters, tubing, and a weight to hold the tubing down all should come with the fountain.
    Intex 8110 SWCG
    "Fear the Schnauz!"
    MikeInTN's Avatar
    Middle Tennessee
    1,335
    Quote Originally Posted by jjdurrant
    They are pretty to watch, and I'd say the lighted ones would be pretty to watch at night. Two things on the con side - they will cause your pool temp to cool down, and you will have to replentish your water more often. Oh, and if you've got salt in your water, then you're putting a salt spray in the air. If you can live with the cons, I'd say go for it.
    Intex 8110 SWCG
    "Fear the Schnauz!"
    Cool. Can I get some pics of yours?
