Thread: Matrix pool sand question
    How far should the sand come up on the bottom wall cuff of the matrix pool. I am using the foam cove. I don't see anything in the instructions about this.
    20,700G | AG | Vinyl | 62 GPM Sand Filter Hayward S244T| 1.5HP/2SP Pump
    cramar's Avatar
    Nov 2010
    Sault Ontario
    1,143
    Re: Matrix pool sand question
    I never found an answer to this when I did mine. My cove was notched in the back so, to me, that meant the rail was supposed to go in there. So I put the cove on the ground and then brought the sand up to it, tamping gently where the 2 overlapped.
    I've seen pics of cove on the ground and cove on the pool sand. If my cove had no notch in the back I would have put it on top of the sand.
    Third season with mine and no problems.
    Sep 2012
    Gardiner, ME
    165
    My pool builder wanted foam coving for a uniform cove...
    24 ft Sharkline Matrix AG
    Waterway 1HP 2SPD Sand Filter 100lb sand capacity, using 50lb of ZeoSand
    TAYLOR K-2006 test kit.
    Installed Spring 2013
    16x16 Deck Going up Soon.
