Results 1 to 9 of 9
Thread: Which first chlorine or PH and TA
    Apr 2013
    New Albany,In
    6
    Which do you do first Super chlorinate or adjust the PH & Alkalinity levels
    pool- 6500 gal IG - fiberglass- 1 hp hayward pump -cardridge filter-sanitizer BBB
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Which first chlorine or PH and TA
    Well, if it needs adjusting, you do PH first. The relationship between PH/TA is complex and can be overwhelming... can make you lose focus, usually the TA can wait unless its insanely low.
    What is your issue, exactly? How does your water look?
    Can you post a full set of results?
    Welcome to TFP!
    Apr 2013
    New Albany,In
    6
    Have not open pool yet will post when open pool thanks Jarsch
    Apr 2013
    New Albany,In
    6
    Re: pool won't shock
    Open pool 3 days ago pump been running since then FC .05-PH 7.4-TA 90-CH 130-CYN 0 HAVE ADDED 5 GAL BLEACH FC IS STILL .05 WATER TEMP 70 water is milky color . Were do I go from here ? Thanks jerry
    38,284
    Are you following the shock process with one of the recommended test kits?
    Defeating Algae
    Turning Your Green Swamp Back into a Sparkling Oasis
    Shocking Your Pool
    If your CYA is truely 0pp, then the sun is likely consuming a LOT of the chlorine you are adding.
    Apr 2013
    New Albany,In
    6
    OK Thanks jerry
    Apr 2013
    New Albany,In
    6
    LAST 3 DAY POOL HAS THESE READINGS FC 3.0- CC 0-TA 100-CH 230-CYN 45- TEMP 80 SHOCKED YESTERDAY 1 LB. CHLORINE FREE SHOCK POTASSIUM MONOPERSULFATE POOL OPENED 2 WEEKS AGO HAVE A NEW FILTER ADDED 5 OZ FILTER AID 1 WEEK AGO. WATER HAS NOT CLEARED REMAINS CLOUDY .CAN ANYONE HELP THANKS JERRY
    38,284
    Please stop with all the capital letters ... it is too hard to read ... and considered shouting and rude on the internet.
    You are not properly following the shock process ... re-read the links in my post above.
    Apr 2013
    New Albany,In
    6
    Sorry did not know cap was rude put items on ebay i use all caps
