Results 1 to 8 of 8
Thread: Bleach?
    Bleach?
    I have a 20,000 gallon pool with no chlorine how many gallons of bleach do I put in ?
    Apr 2011
    Warner Robins, GA
    245
    Re: Bleach?
    lady,
    Please use www.poolcalculator.com
    In addtion please read Pool School at the top right of the Forum to understand the relationship of FC (Free Chlorine) and Stablizer (CYA).
    All of these factors are used to determine the proper levels of chemicals you need to provide proper sanitization of your pool.
    its very easy and we are here to help!
    16 x 32 Grecian Vinyl. Salt-Aqua Plus PS-4, Hayward Pro Series Sand Filter, Hayward Ecostar SP34000vsp, Gulfstream HE-125-T-A Heat/Cool heat Pump
    Re: Bleach?
    the problem is I don't understand what all that stands for
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,007
    Re: Bleach?
    Welcome
    Quote Originally Posted by ladyflamez
    That's why we have
    It only seems overwhelming for a little while.
    38,295
    Re: Bleach?
    Welcome to TFP!
    If you start reading at the top of Pool School, all the terminology is explained and you should quickly get up to speed.
    I am sure you can understand that we are entering the busy season for the forum, and any learning you can do using all the previous documentation is greatly appreciated.
    Posted from my Droid with Tapatalk ... sorry if my response is short
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    Re: Bleach?
    As much as i would like to give you an amount, I can't give you an accurate amount until you provide the following information....
    Accurate test results for the following chemical levels in your pool....you can read about them here pool-school/pool_water_chemistry
    Free Chlorine
    Combined Chlorine
    Total Alkalinity
    Cyanuric Acid
    Acidity/Alkalinity
    An indication of how you currently maintain the chlorine levels in your pool. If you've no idea read here pool-school/types_chlorine_pool
    Maybe explain why you have no chlorine.
    I also need to understand what your water currently looks like. Is it clear? Is it green? Is it cloudy?
    It would be nice to know what type of filter you have and a little about your current maintenance.
    18'x43' Sport Pool
    19,000 Gallons Vinyl Liner 3'-3.5'-4'
    SWCG and D.E. Filter
    Test Kits - Pool Calculator - Chlorine/CYA Chart - Pool School
    Secret Weapon for Pool Chemistry Testing
    Apr 2012
    Southaven, MS
    52
    Re: Bleach?
    It is a bit overwhelming at first, but read through it a time or two and it will make sense... Took me a few to get acclimated to it, but now I get it. Get the numbers and these guys can point you in the right direction.
    - Brandon.
    27,300 gallon in-ground Gunite pool
    1.95hp AC Smith pump
    150 gpm Hayward cartridge filter
    3 Volkswagens and a 73 Plymouth.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Bleach?
    Welcome to tfp, ladyflamez
    A great place to start is: http://www.troublefreepool.com/pool-...efore_you_post
