Thread: Does anyone have the POOL BUSTER MAX? Help!
    Jun 2007
    Charleston, SC
    33
    Does anyone have this older model pool vac (BUSTER, not Blaster), and if so can you take a look at your charger and post the specs? I need to find a replacement for mine... THANK YOU!
    35+ year old 16 x 30 oval, depth 4 ft to 8 ft, in ground concrete pool approx 17,000 gallons-using BBB method
    MikeS's Avatar
    Burtonsville, MD
    22
    Re: Does anyone have the POOL BUSTER MAX? Help!
    I have a Pool Buster Max CG. Here is the Charger.
    MikeS
    28,000 gal pool, gunite w/3M Colorquartz, Pentair CPP420 filter, Quikclean Pop up Heads, Pentair MiniMax Plus heat pump
    1200 gal Spa, Pentair MiniMax Plus Propane heat, Pentair CPP420 filter
    Intellitouch I10-3D Control Panel
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    That is a rebranded RC plane/car charger. Look at hobby suppliers if you can't find it elsewhere.
