Page 1 of 2 12 LastLast
Results 1 to 20 of 27
Thread: PVC Ball valve wing handles breaking
    May 2012
    Allentown, PA
    219
    Just wondering if I need to replace the entire valve or it the handles on these valves pop off and can be replaced?
    Here is a pic. of my valve. Thanks
    http://www.ebay.com/itm/2-Inch-PVC-Ball ... RTM1303753
    21,500 Gallon Vinyl liner pool Eastern Pennsylvania
    Hayward 2 HP pump 2" Pvc pipes Full Sun Pool
    Hayward sand filter, Compupool CPSC 48 SWG
    12mil solar cover and reel
    Re: PVC Ball valve wing handles breaking
    toast
    May 2012
    Allentown, PA
    219
    so basically I need to replumb?
    38,475
    Yup. This is why we always try to recommend true pool valves (like the Neverlube). The PVC ball valves get stiff and then they break resulting in a re-plumb.
    Posted from my Droid with Tapatalk ... sorry if my response is short
    22,553
    Another good thing about the pool valves are that they can be rebuilt without removing them from the plumbing.
    Apr 2012
    151
    If you need to turn them until you replace....try a strap wrench.
    Science and Math Teacher
    Owner - SPS - part time pool biz
    18x36 IG Vinyl, 23000 Gallons with Jacuzzi (the bane of my existance) pumpworks
    Polaris 280 w/ PB4 booster
    Don't always have to replace ball valves if the handles break. Jandy ball valves pop off and can be replaced as long as the valves still function.
    Zodiac R0444200 2-Inch Handle Replacement Kit for Zodiac Jandy Non-Union Ball Valve
    http://www.amazon.com/dp/B008E6J238/ref ... B008E6J238
    May 2012
    Allentown, PA
    219
    This sucks! I have 6 of these valves, and don't have $300 for jandy valves. So it looks like I'm replumbing these. I heard about UV rays giving you cancer, but nothing about headaches!
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    A big pair of channel lock pliers works well too.
    May 2012
    Allentown, PA
    219
    Good News! "Once in while the blind squirrel finds that nut." I contacted the manufacturer and the handle is replaceable. Just use a screwdriver to break off the glued on cap then remove the phillips head screw and the handle will pull straight off. I tested it and it is true. My valves were manufactured by Grandy Company. The part number for the handle is HMIP200. I bought 8 handles for $38 including shipping. No plumbing for me!
    May 2012
    Allentown, PA
    219
    Just in case anyone has the same problem. I figured I would post this video repair to help you out. Thanks for the help and suggestions.
    http://www.youtube.com/watch?v=pY-h1t2KY3s
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Thanks for the video DW
    carlos31820's Avatar
    Nov 2010
    Midland, Georgia
    353
    I was wondering about these same valves in my pool. I painted mine to try to slow down the effects of the sun but I'm glad to see I wont need to replumb whenever those those handles finally break off. Thanks a bunch for the post and video.
    16x36 Vinyl Pool - 22.5K gallons.
    Jandy Stealth 1hp pump - Jandy CS-150 filter
    Jandy Legacy 250k heater - Jandy Ei SWCG
    Jandy Watercolors LED light
    Paramount Vanquish in-floor cleaner
    Apr 2012
    SW Ohio
    456
    you can buy the same valves at lowes for about 3 dollars cheaper and no shipping.......Mike
    18x52 intex ultra frame pool 6981 gallons, 1 HP LL pump with 19 in sand filter,BBB method,borax 50ppm
    leslies DPD test kit + fas-dpd chlorine test kit + borates test strips
    thru wall skimmer,hard plumbed with 2 returns 1 1/2 sch 40 pvc
    1 large fountain 1 inch sch 40 pvc,shut off ball valves on all
    Smykowski's Avatar
    Sep 2011
    3,065
    Quote Originally Posted by doublewide6
    Awesome post, thanks for making the video. I never would have thought you could replace just the handle.
    Yet another reason why I love TFP.
    May 2012
    Allentown, PA
    219
    Quote Originally Posted by fast1971chevelle
    I looked at Lowe's site and you can only buy the valves. The valves are $14.85 each I need 6 of them. I could not find the replacement handles and I'm not sure if these are Granby valves. I http://www.lowes.com/pd_21489-34146-P20 ... fo=ordered 8 handles just to be safe.
    Those Lowes and HD valves are VERY hard to turn. Net impossible for larger valves. Are the Andy ball valves any easier to turn or do you have to go to never lubes to be easy to turn? I need two for slide water throttling. I like the basic handy ball valve with built in union, but it will be located under slide entry where I can't get a wrench, only my hand.
    32K gal, gunite, French Gray DB, IntelliFlo VF, IntelliFlo, WhisperFlo, Quad DE 100 filter, IntelliTouch, IC-60 SWG, IntelliChem, Dolphin M5
    ps0303's Avatar
    Jul 2011
    FL
    3,703
    Go with the never lube valves. Those ball valve handles will break eventually and then you have to replace them again. Do it right and go never lube.
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    Oct 2009
    3,899
    Check the pentair and hayward versions of those never lube valves too...they're just as good, and may be cheaper depending on where you get them.
  20. Back To Top    #20
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Quote Originally Posted by Melt In The Sun
    I was looking at pentair valves since I have seen them quite a bit cheaper, but they look a little different in construction, see the pvc version here: http://pentairpool.com/pool-owner/pr...d-3-way-39.htm also here: http://www.poolsupplyworld.com/Penta...ipe/263037.htm
    Are valves like these any good? Only $20 bucks for 1.5" 2-way or $24 for 3-way...what am I missing?
