This as the way the pool was built, we recently re plumbed all the pipes as they were leaking, and valves were broken.
On the right, intake of the pool drain/skimmer - left of that spa drain and suction intake both into the same pipe to the pump, so I need the pool drain skimmer valve to turn off when I put it in spa only mode. Then I need the second valve on the left to close the suction and open the spa drain, (that one may be easy not really sure) and then on the far left out of the heater there is one valve that is spa return and then pool return, which will need to be shut off to the pool return when in spa only mode. I really just want to be able to switch from pool/spa- spillover mode to spa only mode, turn on the heater(which is done already) and do it all from my remote.
I really don't know the answer to all those questions, I didn't build it, or have it built, it was with the house I bought and I am learning. I am pretty handy and did all the other installs myself, wiring the prologic PS4 and piping, setting up the heater, etc. so I have a good idea of what I'm doing, just can't figure this one out,
What I can figure out is, it seems that the actuators don't stop half way, that are open or closed, which means that I may need to reposition them on the actual valve to archive the result that I want, I may be wrong. Is the configuration in the Configurations Menu?
Sorry for being a pain, maybe I just need to pay someone to do it, just seemd like defeat if I do everything but this one thing!!
