Thread: Liquidator... Are you using it with a 3/8" "kit" or are...
    I'm ready to jump on the board the Liquidator bandwagon (as well as the ph Adjustor!) and I'm seeing that some people are using a 3/8" upgrade kit and others are leaving it as it is from the factory.
    What can you tell me about that? Is there a reason to upgrade?
    Pete
    16000 Gal. Kidney / Gunite / SE Florida / Taylor K2006 / Stenner
    Jandy CS100 / Sta-Rite U3 Skimmer / Pentair Great White / Single Floor Drain / Single Return / Hayward SP2300VSP
    I'm still learning and I know nothing!.. I'm loving the Stenner!
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    Re: Liquidator... Are you using it with a 3/8" "kit" or are.
    Mine is factory. I can empty mine in a day if I open the valve all the way. Whether you need the 3/8" setup depends on your system pressure and suction head.
    Thanks! Our pressure appears to be very strong (we have to dial back the Great White almost all the way!)... so I'm thinking factory is the way to go.
    Thanks again,
    Pete
    22,542
    It's easy enough to upgrade if you decide that it needs it after you get it. What really matters is the amount of suction head your system has. Most inground pools have plenty to run the LQ, most aboveground pools don't.
