Thread: Autopilot 220 Low Amps
    I have the same issue with Low Amp message flashing. Boost is running and did test mode. Results are
    Minerals 2700ppm
    Add 50lbs
    Water temp 64
    28.V 2.0amp
    Chlorine level in pool is low.
    Any ideas why this message is showing?
    JoshU's Avatar
    New Orleans, LA
    542
    Re: Autopilot 220 Low Amps
    At 28v/2.0 amps it sounds like you have a depleted cell. What model cell? How old is it?
    Josh Ulfers - josh@saltpoolguys.com - 888-725-8766
    SaltPoolGuys.com - AutoPilot Pool Pilot Systems, Parts & Cells - AquaCal Heat Pumps
    It is a Compupool SC48 and only a couple of years old. One thing I didn't do when I installed it was recalibrate.
    Ft Lauderdale, Florida
    1,455
    Compupool generic cells are no where built like the factory originals. They typically have less Ruthenium Oxide coatings, thus shorter life. There's nothing really to recalibrate, unless your salt reading was different from a salt test result.
    Sean Assam - Sean@teamhorner.com
    National Accounts and Commercial Products Manager
    AquaCal Heat Pumps www.aquacal.com
    AutoPilot Salt Chlorine Generators www.autopilot.com
