Results 1 to 8 of 8
Thread: Question about a Hayward multiport
    Seanhan's Avatar
    Mar 2013
    Fort Worth Texas
    300
    I have A Hayward 715x R50
    When i select Re-Circulate water slowly comes out of the backwash pipe ...
    Spider gasket ????
    Thanks ...
    Sean Hannon
    30,000 Gallons gunite pool Coated by Fibertech
    Hayward Pro Grid 72 / Hayward multiport
    Circupool V3 VS pump
    CirCupool SWG RJ 60, 400.000 btu raypak , Built in SPA
    38,524
    Re: Leaking multiport valve - question on best course of act
    Likely.
    Seanhan's Avatar
    Mar 2013
    Fort Worth Texas
    300
    Yep took it apart and 2 spokes were gone and the rest of it was shot ..
    Used a go kit from leslies for 15 bucks and wala!!!
    Sean Hannon
    Seanhan's Avatar
    Mar 2013
    Fort Worth Texas
    300
    Hayward 715xr50 multiport valve , replaced all the o-rings now it works but water is leaking from under the handle. I think it might be warn out !! 12 years old. Should i replace the top assembly or the entire valve ???
    Does the bottom part wear out ???
    Sean Hannon
    38,524
    I think there are supposed to be o-rings on the shaft? Or maybe the spring has gotten weak and not forcing a good seal.
    Seanhan's Avatar
    Mar 2013
    Fort Worth Texas
    300
    It could be the spring, i replaced the o-ring on the shaft .
    Thanks !!!
    Sean Hannon
    Seanhan's Avatar
    Mar 2013
    Fort Worth Texas
    300
    I ended up replacing the entire top assembly for 78 bucks
    It fixed it , guess it was just warn out !!!
    No leaks !!!
    Sean Hannon
    38,524
    Re: Question about a Hayward multiport
    Good deal!
    Posted from my Droid with Tapatalk ... sorry if my response is short
