Thread: Need help on refilling above ground pool
    Sep 2007
    middle tennessee
    38
    Am putting a new liner in my pool.....using BBB and salt water.. what sequence of adding stuff would I need to balance my pool?..chlorine,baking soda,acid for PH ect....Thanks
    Above ground 24'round-vinyl-14,000 gal,,1 speed-2 hp pump, 250 lb sand filter ..heated,,salted,,lighted,,decked,,with slide and pool rover jr.....
    TFP 100,,am doing the BBB thing...Wet is Wild!
    Re: Need help on refilling above ground pool
    The details depend on the TA and CH levels of your fill water.
    Briefly, you want to add chlorine each evening. Start working on TA and PH right away. Salt can happen any time after the pump starts working.
