Results 1 to 16 of 16
Thread: App for IPhone
    App for IPhone
    Does anyone know how to find the App for the pool calculator for the iphone? I've search but don't find it. What's it called.
    16X32 Rectangular In Ground Built 1998, New Vinyl liner and Motor 8/2012, 19,000, Hayward Sand Filter, Hayward Super Pump,PoolPilot DIG-220 SWG, 2 Skimmers, Main Drain, Clean Machine Robot, Full Sun, Bleach, TFTest Kit
    Central, VA
    Aug 2010
    Dallas, TX
    4,052
    Re: App for IPhone
    Put in Pool Calculator and it's the 2nd choice. The one with the floating calculator.
    Re: App for IPhone
    psiFlow Technology, inc utilies for $4.99?
    Central, VA
    Aug 2010
    Dallas, TX
    4,052
    Re: App for IPhone
    Yep!
    If you are using iPad and have wifi, the website pool calculator works just fine by the way... but on iPhone the app is better.
    Re: App for IPhone
    Great what a joy that will be to have it pool side.
    Central, VA
    Aug 2010
    Dallas, TX
    4,052
    Re: App for IPhone
    Another option - I use a plastic cup and take 12 or so ounces into the house and do my testing inside, except for the CYA test.
    Re: App for IPhone
    I've done that before also but my pool is a distance from the house so I'm looking forward to doing it all pool side this year.
    Central, VA
    Aug 2010
    Dallas, TX
    4,052
    Re: App for IPhone
    Mine is too. I'm on 1.25 acres and they set my pool in the middle of the back yard.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Re: App for IPhone
    I've got the same app, but mine won't save the settings. Has anybody else had this issue?
    Jeff
    Re: App for IPhone
    Yes, the failure to save settings is a known issue. It's been years and there hasn't been any sign of them fixing it, so don't expect anything to change. It does save settings for a while, how long varies dramatically, but eventually (or often) it loses them.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Re: App for IPhone
    It will save my settings as long as I don't turn my phone off. It's still handy.
    Jeff
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: App for IPhone
    It will probably retain the settings so long as the app isn't explicitly shut down -- when you double-click the Home button quickly and you see your actively running apps. If you close the app in that list, then you'll likely lose the settings. As long as the app is just suspended (which is what apps do when you close them normally), then the settings will likely be retained. Powering off the phone obviously explicitly closes all apps.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Re: App for IPhone
    That's correct chemgeek. If the phone is on and the app is running in the background it saves the settings. I tried sending an email to them but it doesn't work
    Oh well. App still works.
    Jeff
    Apr 2013
    Southern California
    29
    Re: App for IPhone
    Waiting for the android app
    17000 gl. In-ground vinyl pool
    Naturesoft/aquarite SWG t-15 cell
    Vinyl liner measured and installed by me
    38,363
    Re: App for IPhone
    Quote Originally Posted by jdfrye
    SimplePool is developed by a member. I think Pool Pal is as well.
    There is a large thread discussing SimplePool development somewhere.
    Taterfink's Avatar
    Apr 2012
    NE Florida
    536
    Re: App for IPhone
    I don' t know how this would work on an iPhone but with the iPad, you can use Safari to open the web page you want, like pool calculator page, tap on the share button and choose save to home page. It will put a button on your home page that will take you directly to that site. I have a pool calculator button and a TFP button on my home screen. Works great! You can also edit the verbiage for the button name.
    Angie M.
    AG, 26' x 52" Intex Ultra Frame, vinyl, 14667 gal. And LOVING it!!! Hayward S15922S 1HP, 2SP pump and Hayward S220T Sand Filter. Hard plumbed with PVC, added second return, intex SWG, Hydro Pool widemouth skimmer. Set up in May 2012!
    N.E. Florida. TF100 - Best investment EVER! (Well, for the pool anyway)
