Page 1 of 3 123 LastLast
Results 1 to 20 of 41
Thread: Caretaker 99 in floor pool cleaning system giving me issues
    First of all, my pool pump has ~30psi and that routes through the heater, chlorinator and ends at the caretaker head. By the time it gets there it is ~12psi. I think that is the main problem that I have. Should there be more pressure there? Is there anyway to get that higher?
    Then, I have the five head system and each section has 4-5 heads on them. The heads don't fully pop-up as they would if they were out of the pool. Some sections work completely fine, while others (further from pump) don't really work well. They pop-up partially and get stuck up and sometimes don't rotate. I just replaced all of the heads on the pool this week and I'm having these issues (which was ~$1100).
    Any thoughts or ideas or anything that can help fix my pool?? I'm hoping to get this working really well so the pool stays clean and I don't have to go buy a robot.
    A.O.Smith Pump 2HP, Pentair FNS Plus DE Filter 60 (for 60 sqft), Jandy Caretaker 5 port, MiniMax 400 pool heater, Rainbow chlorinator, Aqualink
    Secondary pump for leaf trapper/fountain 1 HP on Hayward Cartridge Filter model C12002
    Polaris 2 peak HP blower for spa
    20,000 gallon pool
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: Caretaker 99 in floor pool cleaning system giving me iss
    Welcome to TFP!
    Seems like the whole pressurized side of your filter should be at the same PSI...do both gauges go to zero when you turn off the pump?
    It sounds like your heads aren't getting enough flow. 30 psi is pretty high. Can you tell use what size/kind of pump and filter you have? How does the water look? When was the filter last cleaned?
    38,448
    Welcome to TFP!!!
    Could be a partial blockage between the chlorinator (keep reading here and you should realize why we do not recommend using these) and the caretaker head. Although it is pretty normal to have a pressure drop between the 2 gauges I think. What is the distance between them?
    Could there a be a problem with the gears in the head that is not opening up each zone completely?
    Most reports here are that these systems do not really keep the pool very clean. I had one a previous house and it was OK, but the dirt seemed to collect in a few places around the pool.
    The dome is brand new so I assume its working correctly. There is probably 8 ft in total between the filter and the caretaker dome.
    20,000 gallon pool
    mas985's Avatar
    Pleasanton, CA
    11,741
    A bit of history would be useful:
    Has the pressure ever been below 30 PSI?
    Is 30 PSI the clean filter pressure (i.e. have you cleaned your filter recently)?
    Has the in-floor ever worked properly?
    Mark
    I just bought the house. I am new to this stuff. But the filter was just taken apart and completely cleaned a month ago. So the filter is clean.
    I really don't know if the in floor has ever functioned properly.
    20,000 gallon pool
    38,448
    Do both pressure gauges go to zero when the pump is off?
    The pool pump goes down to 2. The caretaker goes to 0.
    20,000 gallon pool
    38,448
    If it did not drop to zero, I would replace it and see if you are really at 30psi.
    Posted from my Droid with Tapatalk ... sorry if my response is short
    Replace what? I assume going down to 2 is basically zero on the pool filter. Correct?
    20,000 gallon pool
    38,448
    The gauge. There is no telling if it is reading correctly or not.
    ok, it seems like it is reading correctly. What would be my next thing to debug or do?
    20,000 gallon pool
    mas985's Avatar
    Pleasanton, CA
    11,741
    One thing you should do is fill out your signature with your pool information so we don't have to keep asking a lot of questions. Help us help you.
    Please list all of your equipment.
    What type of filter do you have and can you put it into recirculate mode and does the pressure change when you do so?
    What is your pump make/model#?
    What is your plumbing size?
    Mark
    Oct 2009
    3,899
    Yes, the equipment in the sig is helpful...not trying to nag, but it does eliminate the need to ask so many questions
    Your problem is still not enough flow to the heads. Having the filter cleaned a month ago doesn't ensure that it's still clean, especially if you've had a lot of junk in the pool or had an algae outbreak.
    Since you're new to owning a pool, when you have sometime take a read through pool school (big button in the upper right). It will teach you everything you need to know about pool chemistry, so you never end up getting ripped off at a pool store or endlessly fighting algae.
    I live in TX and it's been cold so there really hasn't been a huge problem with algea. When the filter was completely clean, I set the dial on the pressure gauge. It's up ~2-3 psi since then.
    20,000 gallon pool
    Oct 2009
    3,899
    Thanks for posting that! If you have a multiport valve, try setting it to recirculate and see if that helps. That will eliminate the filter from the loop, so we can make sure that's not part of the problem.
    The pressure goes up 2 psi when on recirculate from 12 to 14 on the caretaker dome.
    20,000 gallon pool
    I was thinking about this a little more. The pool also has a spa which overflows into the pool. I'm going to try to see if I can turn that down so that the pool is getting more of the flow.
    20,000 gallon pool
    quick follow up on my last comment: I don't think I have the control to stop the overflow. I'm actually not even sure where it comes from. There is a actuator that flips closed when the spa mode is on which stops the flow to the pool. I flipped it both ways and couldn't stop the overflow.
    20,000 gallon pool
  20. Back To Top    #20
    mas985's Avatar
    Pleasanton, CA
    11,741
    Redirecting water to the spa may be the cause of the problem. In-floors need a lot of pressure and flow so you may not be able operate other things at the same time.
    Can you post a picture of your pad equipment?
    There may be a bypass that is allowing water through to the spa even on pool mode.
    Mark
