Page 1 of 2 12 LastLast
Results 1 to 20 of 36
Thread: For those in the North, when do you open?
    Jul 2012
    Chicago, IL
    358
    I'd guess the sooner you open the better the chances of opening to clear water, but is there a rule of thumb temperature? My pool is a frozen block of ice right now so opening seems so far off.
    Dedicated TFPer since 2012 with recommended test kit
    AGP, 30 foot, 21,000 gallons with these homemade islands
    Hayward 150 sq foot cartridge filter, 1HP Waterway pump
    Raypak 400K BTU NG Heater! (Installed 2015)
    Installed in 2006? (just a guess, pool came with house I purchased in June 2012)
    Jun 2012
    Hudson Ohio
    47
    Re: For those in the North, when do you open?
    Opened June 10th and closed on September 10th last year...but did not have a pool that we could leave up. Upgrading and getting a heater this year to extend the season...
    18 x 54 Sharkline Matrix pool. 7800 gallons.
    Pentair Optiflo 1 1/2 HP 2 speed pump
    Pentair Clean and Clear 150 Sq Ft cartridge filter
    Hayward H100ID Heater. Purchased all from Poolsupplyworld. TF-100 TEST KIT
    Casey's Avatar
    SW PA
    10,461
    I was opening in April, depending on how April treated us *weather wise*. I would never swim but the kids had jumped in a time or 2. I'm getting a new pool this year and I will probably wait til May to open because it's just my husband and I now and we won't be swimming in the early part of May but I like it open to keep it clean.
    chessie6's Avatar
    East Hartford, Connecticut
    187
    We usually open the 3rd week of April - by then it gets tiresome trying to keep the rainwater drained from the cover so we open just to enjoy the Caribbean color and sparkling water. Once the temps get consistently warmer then we turn on the heater and cover with a solar cover. Can't wait!!
    Summer: 19 x 37 Pacific Graphex IG modified oval, aztec marine vinyl liner, 24,000 gal, 3.5 feet to 8 feet, 1 hp Hayward C4025 Swim Clear 4-cartridge filter, 12.5% Liquid Pool Shock for sanitizing, 1 super wide mouth skimmer, 4 returns (2 therapy jets in steps), Hayward Heat Pro heat pump, non-curved pool slide, 6' jump board, 8 ml blue solar cover, TF-100 test kit, had pink algae in 2010 Winter: Hot Springs Vista Spa, 500 gallons.
    DaveNJ's Avatar
    Toms River, NJ
    520
    May, after the "helicopters fall" Mapple trees.
    IG 18x36 oval vinyl, Spill over spa, Northstar 2hp-2spd, 2.5" piping, S310T 500lb Sand filter, 400k gas heater, AutoPilot SWCG
    http://www.tftestkits.net/
    cramar's Avatar
    Nov 2010
    Sault Ontario
    1,143
    Usually in May when maintaining the cover water is too much of a pain, but we usually aren't swimming until mid june.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Usually sometime in May here...sometimes we even have some cold water swimmers
    EDIT: I should add...if it wasn't for the solar panels, I might not open until June up here, since our nights are still pretty cool at that point.
    I also have to wait until all the "helicopters" are off the trees. I am usually cleaning them up by the several wheelbarrows full.
    Installed Sept 2008. 18 x 36 Flatback Kidney Radiant, Vinyl liner 25,000 inground, Hayward Max-Flo 1 HP Pool Pump SP2807X10 (runs 24/7) , Hayward Pro-Series High Rate Sand Filter Model #S244T, Hayward Heat Pro, Frog chlorinator is turned off, TF-100 Test kit
    Location is Toronto, Ohio, overlooking the Mighty Ohio River. My river days are done. Sold the boat and Waverunner and now prefer a pool over the river.
    Jul 2012
    Chicago, IL
    358
    Since this is the first time opening, I guess I wanted to make sure that I didn't wait too long and open to anything but clear water... which I have always had thanks to finding this site shortly after I inherited a pool and before I started following the bad advice I initially received. And looking out and seeing the water is so much nicer than the covered pool! I think I'll plan on opening in May and cross fingers that I open to clear water, thanks!
    Last year it was really warm and I opened on March 27th (when my water temp hit 60).
    The 27th is two and a half weeks away, I'm sure there is no chance of opening that early this year. It will be mid April for me too.
    Quote Originally Posted by Pauls234
    Last year around this time I was checking my water temp, I went fishing with a thermometer almost daily until the water hit 60.
    Aaron
    [ Vogue Vectra 24' AG | Hard plumb: Hayward Power-Flo Matrix 1HP 2-speed, 27" sand filter & Pentair MiniMax 100 NG | Taylor K-2006 | Central IL ]
    Powered by: TFP, PoolMath & TFTestkits
    I was also looking for info on when to open an above ground with a heater. We bought a heater at the end of last year and fired it for one weekend to make sure it works. It was a used heater.
    Just to reiterate..
    The important number is the water temperature. When the water temperature gets to somewhere between 50 and 60 degrees it is time to open the pool. You can put it off longer than that, but the chances of having an algae problem on opening increase as the water gets warmer.
    I need to check mine tonight and see where it's at, I'm guessing low 40s.
    Aaron
    Mine still has ice on top. Will be awhile here lol.
    Jul 2012
    Chicago, IL
    358
    I don't think I have any water in mine, I think it is frozen solid! Despite rain and 50 degrees yesterday, all of the snow and water on top of my cover is still icy. My guess is the giant 20,000 gallon ice cube below is keeping it cool.
    And thanks for the temp tip Aaron, that is what I was looking for but could not find in the above ground pool opening write up... was it stashed with the inground pool opening?
    No problem. I searched for opening temperature and found it in Swimming Pool Care / Just Getting Started, this is the thread I quoted.
    Aaron
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Quote Originally Posted by DaveNJ
    +1...darn helicopters
    mariane's Avatar
    May 2012
    Southeast Michigan
    305
    This northerner is getting antsy reading about all those southerners opening their pools.
    I'm liking the idea of getting rid of the cover and looking at sparkling water ... but ... the last few years the ducks and birds have been swimming in my pool cover and leaving the "bird bath" remains behind. They did the same once the cover came off and it took me the longest time to figure it out. The OCLT was positive and could not figure out why until one early morning I could those ducks "red-handed" swimming in my clean pool.
    Do you all have trouble keeping the pool clean this early? If the weather continues this way for the next week, the water temp will be 50, and I guess the process starts. I'm planning on getting the hoses attached soon (in the next few days) and the filter and pump ready to go.
    Would you also start running the pump this early? Or, like they say with planting flowers, don't do anything till the last frost of spring.
    16 x 28 Doughboy Mystic Garden AGP with 7' deep end (used expandable vinyl liner) ~11,800 gals. Deep end main drain. Thru-the-wall skimmer, one return at deep end. Media Master 150# sand filter. Doughboy PowerPak II pump, 1 hp. Pentair MinimaxCH 150m natural gas heater. Polaris 65 when it feels like working . TF-100 test kit. No longer 'pool stored' 6 years and counting. In sunny but fickle metro-Detroit.
    We are in PA, probably going to open it mid-may.
    Semi IG, Vinyl, Sand, Built in 2012, Lives in Eastern PA.
    Jun 2007
    New Jersey
    653
    I wait until the nights are into the 50's. Usually end of April, first week of May. I have never opened to green. Water temp is usually 50-55F. Probably two weeks from now.
    Current: 28,000G 18'x36' I/G AnthonySylvan Plaster; Waterway 60 sq.ft. DE Filter; 1.0hp x 1.65 SF Two-Speed (B2982) WhisperFlo; 2004-Present
    Previous: 40,000G 20'x40' I/G Koven unlined WWII salvage 5/8" marine steel; Lomart Stainless Sand Filter; 3/4hp Hayward SuperPump; 1946-2003 (managed by me from about 1964)
    Ancient Taylor K-2000, upgraded with Taylor CH, TA, and FAS-DPD, and TFT CYA tests.
  20. Back To Top    #20
    Quote Originally Posted by Durk
    Sounds great. I'll be doing the same
