Thread: Testing Ph while shocking for algae.
    Could you tell me will a high chlorine level effect Ph testing? I am shocking for algae and am wondering if I should test the Ph levels while keeping up my chlorine up to shock level. Thanks for the help, Cannwmor
    20,000 gal. IG pool/ 400 gal. spa combo, unpainted plaster; Hayward Pro Series sand filter; Whisperflow 1.5 hp pump; Pentair Minimax pool & spa heater; Save-T Cover II Automated pool cover; Maytronic Dolphin; Dragonfly pool skimmer; Baquacil.
    Re: Testing Ph while shocking for algae.
    Welcome to TFP!
    Generally you shouldn't test PH while shocking. The PH test is reliable up to an FC level of 10, usable but not perfect from about FC 10 to 18, and useless at FC levels above that.
    Thank you for your quick reply. Very helpful.
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    cannwmor:
    Next time you have to shock, I would lower the pH to around 7.2 before you begin the shock process. Chlorine is more aggressive as a sanitizer at a lower pH. Don't overdo the pH adjustment, though...7.2 is a good target, but make sure you do not go below 7.0 under any circumstances.
    Once you begin the shock process, do not bother testing the pH for the reasons Jason stated.
