Results 1 to 9 of 9
Thread: Wiring Pentair UltraTemp to Intermatic RC2163
    Hi,
    Please, share wiring diagram connecting PentAir UltraTemp 125K to existing Intermatic RC2163, if available.
    Thank you.
    Built 2005, 15k IG Pebble, bean shaped + spa with spillway, 7.5' deep end, 30" shallow
    1.5" skimmer & 1.5" navigator lines, 2" at pad, 2nd story solar heat, 2.0 hp FloPro VS-FHP2.0 pool pump, Sta-Rite S8M150 Modular Media Filter, Heater (don't know - don't use because of Solar), Chlevachlor RP30 salt cell, 2hp spa Sta-Rite booster for spa
    Jandy RS2/6 One Touch Rev L, 4 relays in use, 2 spare AUX but no relays
    22,553
    Re: Wiring Pentair UltraTemp to Intermatic RC2163
    Look at page 4 of the timer manual and page 12 of the heater manual and that should give you an idea obout the connection. Use spa and com on the timer.
    Thank you for your reply. Manual for the Intermatic is missing unfortunately. I have three wires coming out of it:
    -orange (was connected to "L" terminal on old Hayward heat pump)
    -blue (was connected to "C" terminal)
    -green (was connected to "H" terminal).
    Page 12 for Pentair presents well more options . Any advise?
    Thank you
    Found manual for RC 2163 on-line. Pentair Heat Pump has SPA- COM- POOL connectors on the diagram. Intermatic has C (COMMON)-H (HIGH)-L LOW).
    Which wire from Intermatic goes to H and which one to L?
    Thank you
    22,553
    Assuming you want only to heat the spa, use the SPA and COM terminals on the heater and use the H (green) and C (blue) on the timer. Tape or wire-nut off the L wire on the timer.
    Thank you. I do want to heat both: pool and spa. Does it mean that Green wire from timer goes to POOL?
    22,553
    You should be able to put a jumper between POOL and SPA and it'll heat whenever the timer is on. I'd call Pentair and make sure that's how it should be done.
    Thank you very much.
    Got response from Pentair: ORANGE goes to POOL; BLUE to COM; GREEN to SPA.
    Thanks again.
