Is there somewhere in pool school that explains safe use of muratic acid? If not, could you give me some safety tips.
RobbieH said:Wear goggles, pour slowly near a return to avoid sloshing, and try not to breathe the fumes.
I'll also mention I recommend against storing opened bottles indoors, as the fumes can be corrosive.
bobodaclown said:I'm not a proponent for using the bucket and handling it twice. Stand up wind and pour in.
RobbieH said:I don't wear gloves. I also guesstimate ... a few ounces here or there aren't going to make much difference in my pool!
y_not said:BTW, acid will completely dissolve nitrile/latex gloves in a fraction of a second. You have to use acid resistant material.
chem geek said:If you poured VERY slowly in front of a return flow and aimed well, then you might thoroughly mix the acid with the water, but generally speaking it's a good idea to brush the pool surfaces in the area where you added the acid. At one point, I got lazy about brushing after acid addition in my own pool and I can see some pitting of plaster in the general area where I added the acid.
jjslinger said:y_not said:BTW, acid will completely dissolve nitrile/latex gloves in a fraction of a second. You have to use acid resistant material.
Good point. I googled it and found this Chemical Resistant Gloves where it says nitrile is okay for "incidental" contact with hydrochloric acid but neoprene or butyl rubber would be preferred for longer term contact.
y_not said:By "incidental" I presume they mean an occasional splash won't melt holes in your hand?
IE. You don't wanna dip your nitrile clothed hand into the acid. YIKES!!
y_not said:So is pouring it in front of an active return, in the deep end at full strength safe enough? Or do you really "HAVE TO" brush right away?
