Results 1 to 7 of 7
Thread: Hawkeye spa heater
    Hawkeye spa heater
    Hey, I am new to the forum and my question is my Hawkeye spa will not heat over 97F.The former owner replaced the master board two years. Any ideas?
    25000 Gallon IG Pebble Tec tr-100c Triton II Commercial Sand Filter Intelliflo 3hp variable Speed Polaris 360 with Booster Pump
    JoshU's Avatar
    New Orleans, LA
    542
    Re: Hawkeye spa heater
    Any error codes on the digital display?
    Of course you will want to completely shut off power to the spa before checking these things:
    Could possibly be a bad board again. If you are comfortable with electronics you may want to inspect the board for any damaged spots.
    Hopefully it's something cheaper like a bad heating element. Heating elements are fairly easy to replace and aren't too expensive. Do the connections to the heating element appear to the be tight and good?
    Josh Ulfers - josh@saltpoolguys.com - 888-725-8766
    SaltPoolGuys.com - AutoPilot Pool Pilot Systems, Parts & Cells - AquaCal Heat Pumps
    no error codes. I have not looked the board over for any hot spots. I hope its a bad element but I do not know where they are located. Thanks, Bill
    JoshU's Avatar
    New Orleans, LA
    542
    Quote Originally Posted by 4hawkman
    It should just have a single element installed. Typically you will find it inside of a stainless steel tube near the box that houses the control board.
    Yea I found it, The stainless tube has two plugs which I assume are two heaters. It will heat up to about 97 degrees but I cannot get it to go above that. Thanks!
    Knoxville, TN
    41
    If you have a mutimeter check voltage at the heater lugs. If the topside is calling for heat you should have 240v across both legs of the heater.
    If its getting proper voltage but not heating, if you have access to an ampclamp(a device that measures current), check amp draw on the incoming power to the board. That is normally the easiest place to check amp draw. A typical 5.5kW heater will draw around 23-24 amps. Low speed on the pumo when heating will be around 3-4amps. If you only see the 3amps and the tub is calling for heat with proper voltage to the heater, your element is bad.
    Good luck!
    Hot Springs certified service tech A
    APSP CST Certified
    CPO Certified
    Thanks! I will let you know what I find
