Thread: Help replacing bearings on Pentair need shop recommendation
    My pump works but is making a lot of noise and vibration, I took it apart and is not clogged or anything. After reading different posts in the forum, I realized that it is probably the bearings. Can someone recommend a shop around the inland empire area (ontario) where I can get my motor refurbished with new bearings?
    Thank you
    Francisco
    poolsupplysales's Avatar
    Jan 2012
    Tulare, CA
    112
    Re: Help replacing bearings on Pentair need shop recommendat
    You would be better off to replace the motor if the bearings are bad the windings will be next
    Quote Originally Posted by poolsupplysales
    I was hoping that getting the motor refurbished would be cheaper than getting a new motor/pump.
    Qwaxalot's Avatar
    Jun 2012
    439
    Quote Originally Posted by fcienfuegos
    I'm with poolsupplysales, if you can even find a rebuilder, I'd guess a rebuild would be north of $150.00, a new motor $230.00 to $300.00.
    We've occasionally replaced bearings on pump motors; but only rarely.
    In the industry, CSP (Certified Service Professional) by the NSPI and it's successor the APSP. My company services over 600 pools every year. I think the practices regularly espoused on this forum (especially the BBB method) are outstanding; however my comments will be often oriented towards the goal of getting it done, and getting it done right now!
    38,524
    And since you need to deal with the motor, maybe now would be the time to consider upgrading to a 2-speed motor on your existing pump. May cost a little more up front, but running on low will save you a considerable amount of money on electricity in the future.
    Just some food for thought ... although at this point we do not know anything about your pool setup and flow requirements to offer any suggestions.
