Thread: Whoops- I left my test kit outside overnight in the rain
    May 2012
    Elk Grove, CA
    60
    The individual regent bottles were closed, but the blue case was left open and had a bunch of rain in it. Are the regents still good?
    This is a Taylor K-2006, btw.
    16k gal IG pool with SWG and DiamondBrite finish
    Pentair Intelliflo pump with 520 sq ft cartridge filter
    38,475
    Re: Whoops- I left my test kit outside overnight in the rain
    If the reagent can't leak out, the water could not leak in. So they are not diluted if that is your concern. What was the overnight temperature?
    More concern would be if you left them the 100 degree sunlight all day.
    Likely, everything is fine.
    Posted from my Droid with Tapatalk ... sorry if my response is short
    May 2012
    Elk Grove, CA
    60
    Overnight low was in the low 50s.
    I had my PH sample sitting there for 36 hours
    Feb 2008
    Denton, TX
    5,061
    As long as everything was capped tightly, I think that you should be good.
