Results 1 to 12 of 12
Thread: 15,000g how much absorbic acid to lower 1ppm of chlorine.
    Oct 2010
    michigan
    284
    Need to do an AA treatment before closing, stuck at 5ppm chlorine, water is so cold 60 degrees, its not dissipating.
    15,000 gallon inground fiberglass pool with spa. 350lb Sand filter, 1.5 hp pump, and heater
    UN1017's Avatar
    May 2012
    Sacramento, CA
    288
    Re: 15,000g how much absorbic acid to lower 1ppm of chlorine
    Ok...it takes 1 gram of AA to neutralize 1 milligram per liter of Cl per 100 gal of water.
    Not taking density into account and since we are dealing with low concentrations in water in think we can say the 1mg per liter is the approx the same as 1 ppm. So you would need 150 grams or 5.3 oz by weight.
    chemgeek...you're our only hope!
    I would just add a little at a time and keep testing to be sure. So...if you try to do AA now it looks like your first pound and a half will get eaten by the Cl.
    15'x30' IG - Roman-style - 14K - Pebble Fina Classico
    Filter: Jandy CL460 Pump: Jandy Stealth SHPF1.5 SWG: Jandy AquaPure 1400 Cleaner: Jandy RayVac Test Kit: TF-100 w/SpeedStir
    Chlorine/CYA Chart----Extended Test Kit Directions----SLAM
    Oct 2010
    michigan
    284
    Eek that is a bummer, will have to wait i guess, maybe i should pee in the pool? lol j\k
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,766
    Isn't there a chlorine neutralizing chemical, forget the name of it...thiosulfate-something? You can buy it for this exact purpose...
    In ground vinyl Grecian, 24k gal, Hayward 220t sand filter, VGreen VSP 165, Hayward SWG, Raypak NG 265k heater, dolphin m4.
    Helpful Links:
    GET A TEST KIT Chlorine/CYA Chart How to SLAM About Metals & Stains
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,766
    Just asked dr. Google...yes, it's sodium thiosulfate and it takes 5 oz per 10,000 gallons.
    Perhaps it's cheaper than blowing through almost a full treatment dose of AA.
    Helpful Links:
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,766
    Also note. Did an AA treatment with cold water a few weeks back. Expect it to take considerably longer to net the kind of results you would at 70 degrees and plan accordingly (I didn't!)
    Helpful Links:
    UnderWaterVanya's Avatar
    Jun 2012
    Mint Hill, NC
    2,589
    Why do you need to drop the FC at all?
    EDIT: I just reread this and figured out what you want to do. Essentially you need to drop FC before you do the AA treatment - right?
    -sent with Tapatalk 2
    Oct 2010
    michigan
    284
    Quote Originally Posted by Swampwoman
    How long did it take you? I have 3.5lbs of AA for 15,000 gallons, so gonna over dose it a bit.
    Will have to go get that sodium thiosulfate as i don't want to burn too much AA lowering it.
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,766
    Mine was incomplete after letting it sit for two days. My problem was that I had to hurry up and bring the chlorine ack up efor my son's pool party. The fresh stains were all ge the first day, but the historic stains/streaks merely lightened.it probably depends on your stains!
    Helpful Links:
    Oct 2010
    michigan
    284
    what was the temperature of your water when you did it?
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,766
    About 60 degrees.
    Helpful Links:
    Mar 2007
    San Rafael, CA USA
    12,082
    1 ppm FC in 10,000 gallons would get eliminated with 3.3 ounces of ascorbic acid so in 15,000 gallons that's 5.0 ounces.
    You can neutralize chlorine by using a chlorine neutralizer such as sodium thiosulfate or you can use hydrogen peroxide. It takes roughly an equal volume of 3% hydrogen peroxide to neutralize the same volume of 6% bleach. So for 1 ppm FC in 10,000 gallons, that's around 21 fluid ounces. For 15,000 gallons, it would be around 31 ounces or roughly 4 cups of 3% hydrogen peroxide for 1 ppm FC. You can also get Baquacil Oxidizer which is 27% hydrogen peroxide and use 1/9th the volume. So to get rid of 5 ppm FC in 15,000 gallons, it would take around 17 ounces (about 2 cups) of Baquacil Oxidizer.
