Thread: Bi-Carb Startup
    bigfunky's Avatar
    Jun 2012
    Wayne, PA
    137
    Bi-Carb Startup
    Just curious if any homeowners have performed a bi-carb startup as recommended by OnBalance. It seems to be great way to preserve the plaster and get the maximum life out of it.
    26,000 gallon gunite IGP with 50 sq ft Spa, Jandy VS FloPro 2hp Pump, Jandy DEV48 Filter, Jandy AquaPure SWG, Jandy AquaLink PDA-PS6 Controller, RayPak R406A Heater, Polaris 380 Cleaner, completed April 2013
    Aug 2009
    Northern CA
    30
    Re: Bi-Carb Startup
    Unfortunately, most homeowners are not going to venture the hassle of a Bi-carb Start-up. But yes, we have done them and we definitely recommend them! If it was my pool plaster, there is no way I would not do one.
    bigfunky's Avatar
    Jun 2012
    Wayne, PA
    137
    Re: Bi-Carb Startup
    Other than buying the 55 gallon drum (which I think I can get at work for fee), hose and chemicals it doesn't really seem like that much of a hassle.
    My pool is built and l'll be plastering in the spring, I'm gonna do it.
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: Bi-Carb Startup
    Please keep us updated!
