Results 1 to 11 of 11
Thread: Volt Meter to Check Salt Cell?
    Aquatica's Avatar
    Jun 2010
    Nassau, Bahamas
    514
    can we use a volt meter to check to see if a cell is good or bad? Thanks.
    Jul 2007
    Brisbane, Australia
    874
    Re: Volt Meter to Check Salt Cell?
    kind of
    what you really need is a fluke so you can test both voltage and current
    that, along with salinity test will paint a more accurate picture
    Aquatica's Avatar
    Jun 2010
    Nassau, Bahamas
    514
    Thanks. Much appreciated. Will look for a Fluke.
    22,544
    It doesn't have to be a Fluke as that's a brand name. A good multimeter that will measure DC volts and amps is what you should look for. I have a clamp-on that'll measure DC amps. Those are the best but are a little expensive.
    Aquatica's Avatar
    Jun 2010
    Nassau, Bahamas
    514
    Thanks Dave. so I need a multimeter. Then I need to figure how to test the cell with it. I usually just use a replacement test cell which I know works but we only have hayward cells. sometimes need to test other makes.
    Jul 2007
    Brisbane, Australia
    874
    yeah, doesn't have to be a Fluke, just any good clamp on
    as long as it can measure DC up until 50 amps you should be fine for any of the residential units
    to test it you make sure the salinity is within the recommended range, then crank up unit to the max and measure voltage and current. if the voltage is at the max and current is lower than normal, then it's highly likely the cell is bad.
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,691
    I use my inductive (clamp on) meter to measure amps on a cell while running. On Aquapure 1400 cells, i get about 7 amps hooked on to the green wire. inductive meters only work if you can get it on one wire. So that usually means you have to remove the cover on the box, and grab the cell wire on the other(box) side of the plug.
    Factory Warranty Station for:
    Aquatica's Avatar
    Jun 2010
    Nassau, Bahamas
    514
    Thanks for the info. Most swg's display cell amps? and volts. I know AquaRites do. Do we really need to measure amps since the control panels might be doing this for us?
    Jul 2007
    Brisbane, Australia
    874
    if you trust the reading then you don't need to.
    i guess it also depends on whether they actually measure amps, or calculate them based on some formula
    mas985's Avatar
    Pleasanton, CA
    11,737
    Amps cannot be measured directly but can be measured as a voltage across a known low value resistor in series with the circuit. With a known voltage and resistance the current can then be calculated using Ohms law (I=V/R). This is the same way that some multi-meters measure amps (i.e. non-induction type) and I suspect that SWGs use this same technique because it is both simple and cheap to implement. I doubt they would use an induction coil. But either way, the measurement should be accurate as long as everything is calibrated.
    So the amps and voltage readout of a SWG should give a reasonable indication of cell performance. However, the salt level readout is definitely a calculation and in addition to amps and volts, requires a temperature measurement to get an accurate salt level although not all SWGs use temperature in the calculation. SWGs that don't use temperature in the salt calculation tend to have high error at low temps. But this type of salt measurement is a basic TDS measurement so anything that increases conductivity such as calcium and magnesium will inflate the salt measurement. Temperature will also increase conductivity which is why it needs to be compensated for when calculating the salt level.
    Mark
    Aquatica's Avatar
    Jun 2010
    Nassau, Bahamas
    514
    Thanks for the info Mark. I should be ok to use the control panel readings to see if cell is bad. I carry a Taylor salt test to double check salt readings. Thanks again..
