Thread: Question on blowing out supply side....
    Sep 2012
    PA
    5
    I plan on closing my pool myself. I watched what the pool company did last year and don't think its worth anywhere near what they charge!
    I just have one skimmer and a floor drain. There is a diverter valve in the skimmer that they remove. I do not have a shut off valve for the floor drain. I have a gizzmo for the skimmer.
    When I start blowing at pad side, do I blow until I see bubbles coming out of the drain and both holes in the Skimmer? The gizzmo threads into one hole...what do I plug the other hole with? Rubber plug? I assume no antifreeze gets added to the floor drain pipe? The gizzmo has a cap on top...is this where the antifreeze gets added?
    Now for extra insurance...can I add a pop bottle partially filled with antifreeze to the skimmer for freeze protection?
    Nov 2011
    Moberly,MO
    1,010
    Re: Question on blowing out supply side....
    ridgeway I understand your thoughts on there charges. But remember if it freezes and breaks it will be expensive to fix.
    Over 30 years in the pool business
    We build vinyl, fiberglass, stainless steel pools
    Certified in Hydraulics
