Thread: Partial drain or not?
    maryann79's Avatar
    May 2012
    Louisville, KY
    62
    We're starting our first closing tomorrow. Is there a preference as to whether we drain below skimmer & return or use plugs & leave water level up?
    Thanks!
    Pool: 27' x 52" AG, about 16,500K, cartridge filter
    Waterway 175 sq ft 1.5 hp pump 2-speed
    Deck first of June!
    May 2012
    Endicott NY
    87
    Re: Partial drain or not?
    Same question here. I drained below skimmer and return...should I just plugged return? And left water above return? I'm in NY.
    21 10500 gal AGP 52' sides, haward 3/4 hp xl pump and earth filter ec50
    Using the bbb method. Tf-100 kit. My first pool so learning in progress!
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    I've done both and prefer dropping below skimmer and leaving the valves open (my skimmer door leaked). Yes you will lose more water but less risk of the skimmer cracking. If you decide to plug, make sure to use a skimmer door and a Gizmo in the skimmer as back-up freeze protection.
    May 2012
    Endicott NY
    87
    I'm below the skimmer and the return, was there a need to go below the return? Pump, filter and hoses have been removed, so return is now just an empty fitting with eye removed, but body still installed. I ask this because return is below skimmer, so I'm about 10 inch below bottom of skimmer and a few inches below return. I don't want to drop it any more. If I put a plug in the return,do I have to worry if the water raises to the plugged return with melting snow and rain?
    I apologize to the Original poster for jumping in...but I think we have the same question..
    Geo
