Results 1 to 11 of 11
Thread: Store chemicals in winter/snow
    Jun 2012
    NJ
    40
    Where are you supposed to store chemicals over the winter? I am in NJ so we get cold/snow - not sure if that changes the answer.
    Outside? garage?
    I did a quick search and saw the post about keeping certain things separate.
    NJ
    35,000 gallons, DE filter, IG plaster
    TF-100
    Jul 2012
    Dumfries & Galloway, Scotland
    296
    Re: Store chemicals in winter/snow
    mostly should be kept in a cool, dark place, Garage would be good, keep acids and alkalis seperate from each other:
    Alkalis:
    Bleach
    Cal Hypo
    Calcium Builder
    Bi-Carb
    etc etc
    Acids:
    Tri Tabs
    Muriatic Acid
    etc etc
    Regards
    Stuart
    Stuart Murray
    Scotland UK
    UK NPPOC
    30,403
    What are you planning on storing?
    Jun 2012
    NJ
    40
    de, tablets (leftover from before i learned of this site so now we only use them when on vacation) and a few things of shock - cal hypo i think
    NJ
    TF-100
    Jun 2012
    NJ
    40
    also how long do they ;last?
    NJ
    TF-100
    Jul 2012
    296
    DE Tablets? Is that Hypo De Calcio Chlorine tabs (ie Calcium Hypochlorite)?? - Had to google that!
    If your storing Cal Hypo products there's no discernible shelf life to it unlike Bleach, providing you keep it airtight to avoid any dampness setting in
    Stu
    Stuart Murray
    Scotland UK
    UK NPPOC
    Jun 2012
    NJ
    40
    no DE for the filter and chlorine tablets (i think tri)
    NJ
    TF-100
    Jul 2012
    296
    Ahh, Ok, DE is Slightly Alkali, Tri Tabs are Acidid, so store in airtight containers with a reasonable distance between them.
    EDIT: Just read your thread and didn't notice the coma between the DE and Tablets - apologies!
    Stu
    Stuart Murray
    Scotland UK
    UK NPPOC
    Mar 2007
    San Rafael, CA USA
    12,082
    Just FYI for others (since you're not storing pure acid), I wouldn't store Muriatic Acid in a garage. It has a pressure-relief cap so can expel hydrochloric acid gas that is VERY corrosive. The bottle should be put in an area with good ventilation and far away from any metal. If you have full-strength Muriatic Acid (31.45% Hydrochloric Acid or 20º Baumé) then it can be stored outside since it's freezing point is -46ºC (-50.8ºF) as described in this post.
    Jun 2012
    NJ
    40
    Thanks
    Is there a shelf life for the DE or the chlorine tablets?
    NJ
    TF-100
    Jul 2012
    296
    Quote Originally Posted by Stuamurr
    ^^^ this
    The same applies to DE
    Regards
    Stu
    Stuart Murray
    Scotland UK
    UK NPPOC
