Thread: Plaster versus vinyl pool care
    Mar 2009
    Charlotte, NC
    539
    I will soon be helping someone with a vinyl pool. I'm pretty familiar with caring for my plaster pool..I see that the recommended levels for CH are different. Other than that what else can you tell me that I should know, or can you point me to a link that would explain the differences.
    Thank you
    19,800 gallons (closed/winter 18,654 gal); plaster; 18x34 Ft kidney bean shape, Depth 3Ft-5Ft. Built 1992
    Pentair Whisper Flow Pump 1HP. Winter safety cover w anchors.
    Sand filter, Pentair Sand Dollar Top Mount Model SD80; Effective Filtration Area 3.5SF
    - FlowRate 75GPM, 8Hr 36,000, 10Hr 45,000, 12Hr 54,000; Pressure Weight 50PSI
    BBB (Hayward Chlorinator when leave town). Polaris 360 cleaner.
    38,239
    Re: Plaster versus vinyl pool care
    The chemistry is the same. Only difference is that a low CH does not matter for vinyl:
    pool-school/recommended_levels
    22,542
    A vinyl pool is just like a plaster pool as far as the levels go except a vinyl pool doesn't need CH. High CH is a problem for all pool surfaces.
    You can also set the pool calc for a vinyl pool.
    Butterfly's Avatar
    South Carolina
    10,045
    What they said ^^ and,
    Lots of folks with plaster pools are using the wrong brush. So, fyi:
    Use a Nylon brush for vinyl, fiberglass, tile, and plaster that is less than one year. (Plaster includes any exposed aggregate and marcite finish, btw!) Combo brushes are for older plaster. All stainless are for algae (very stubborn green algae and also the ONLY brush for black algae.)
    You CAN unscrew the Wall Whale from the nylon brush it comes with and screw it on a combo brush if your plaster is over a year old. Newer plaster is really too soft for anything other than a nylon brush.
    You're done SLAMing when:
    38,239
    I love the wall whale ... but I too have the wrong brush
    The nylon one is almost dead, so I will be getting a combo one next.
