Results 1 to 9 of 9
Thread: 18x48 Ultra Frame build
    Some pics of our 18x48 install. Nothing like picking a few 95+ degree days to do it on
    Currently a big sand box with no pool, 18"x54 on order
    Hayward EC40 filter with Hayward 1HP pump, Wanda the Whale
    SWG
    Re: 18x48 Ultra Frame build
    SWG
    SWG
    SWG
    R.J.'s Avatar
    Jul 2012
    Minneapolis
    82
    Excellent job! What's the water temp?
    18 x 48 Intex Ultra Frame
    2500 gph cartridge filter
    Intex SWG
    It's currently 86, but with some colder nights and highs only in the 70's and low 80's i'm sure it gonna go down to about 80. When we were filling it up we put the solar cover on it and had 82 degree water when we finished, haven't looked back, we actually hit 94 a few weeks ago when the temps were over 100 for a few days. Next year is a 4x20 solar panel on the garage roof and a deck if the building inspector lets me get away with a few variances.
    SWG
    Apr 2012
    SW Ohio
    456
    i was gonna ask about the location you placed the pool,are there are no regulations on the distance between the pool and structures i.e buildings,fences?
    water looks great and i like how you hard plumbed the pump to the filter are you planning on hard plumbing the rest and a thru wall skimmer and water features? very nice job.....Mike
    18x52 intex ultra frame pool 6981 gallons, 1 HP LL pump with 19 in sand filter,BBB method,borax 50ppm
    leslies DPD test kit + fas-dpd chlorine test kit + borates test strips
    thru wall skimmer,hard plumbed with 2 returns 1 1/2 sch 40 pvc
    1 large fountain 1 inch sch 40 pvc,shut off ball valves on all
    Apr 2012
    SW Ohio
    456
    here is a pic of mine
    a small video
    Only regs i had to follow for that were keep it 3ft on the back property line and 2ft from the side. We have all none conforming lots since the yards are so small. I have it 3ft from both lines and 2 ft from the fence which is mine. If you notice i was allowed to keep the nice side of the fence in so my neighbors can stare at the unfinished side.
    Hayward skimmer is next year same with hard plumbing the rest the feed and return. I am not sure if i am going to move the filter a bit and didn't want to have to redo the work. And i am still not sure if i am going to use pvc pipe or irrigation hose to run the water to and from the solar panals. I would think that i might lose heat on the return if it's white pvc. Then again that's nothing a little krylon can't fix.
    I want to take the deck right up to the fence, those also have to be 3ft off the line, and i want to go 6ft high with privacy fence on that.
    SWG
