Page 1 of 3 123 LastLast
Results 1 to 20 of 44
Thread: Pool has started ....oops, a wee rock !
    Here was the plan.......
    KC in Ottawa, Ont. Canada........62.5k L(16.5k us gal) IG Vinyl Pool. 18 x 32 Odysee II. Hayward S270T sand filter and 1.5hp pump. Zodiac Duo Clear 130 Salt System(up to 130k L), Raypack Digital Pool Heater.
    Here is the reality......
    Two rocks actually ...... about $3000 worth ......assuming you value rock by the rule of how much it costs you to buy, or remove .... maybe i should save any large pieces for framing the pool ?????
    Apr 2008
    Central Texas
    326
    I live near several limestone quarries, so you can imagine what the ground is like in this area. My sister lives about a mile from me and got a quote for their pool to be built a couple of summers ago. The company did stick with their original price quote, although it turned out that my her backyard had a HUGE slab of limestone just below the surface. Imagine a jackhammer running in your backyard for 11 days, 10 hours per day... :-O It was one of those that mount on a backhoe, so it was not a toy. The PB said that it was the hardest dig that they have ever had.
    That's one fine looking rock that you found. Have you figured out the cost per ton?
    26,000 Gallon Gunnite IGP
    2 HP Challenger High Head Pump
    60sf Nautilus DE filter
    Polaris 280
    I need that rock ! what will you charge to ship it to me ?
    14,500 inground gunite
    7' connected spa with overflow waterfall
    Goldline salt water chlorine generator
    Hayward 4 cartridge filter
    Hayward 400K heater
    Completed January 07
    May 2008
    Austin, TX
    27
    That was us too, we wanted to put our Doughboy 3 ft into the ground, a foot or so down we hit indian artifacts, arrowheads, a mortar and pestle, knives used to tan hides, ect. at 2 1/2 ft down we hit a shelf of rock so big it went under our patio and house. We didn't want to jackhammer for 6" so they filled it back up to 2 ft and we have a tiered deck now.
    I did have them leave a couple of the bigger rocks they dug out, they're a great accent.
    12' x 28' Doughboy, partially underground, 9100 gal. Hayward pump and sand filter, Barracuda Zippy pressure side cleaner.
    Jul 2007
    North of Dallas
    207
    keep it and design your waterfall over it... like a nice sheet of water flowing over for a nice waterfall feature. it's too nice not to do something with... but it is big!
    My Pool - 18x24 fully setup Cabana, 22x48 gunite/quartz plaster (3-5-3 depth) & 8' spa w/ spill and 5' natural rock waterfall; Hayward DE filter/pumps/heater; Hayward Pro Logic controller; Phantom cleaner. Finished 06/01/07.
    RedishConstruction.com
    Our ground is also very rocky, but not nice boulders like you seem to have... we have about 1/2" of red clay over sheets of shale. Not very usable for our purposes...
    to plant a flower requires a pick-ax!
    I would also keep them for use as waterfall base or just as a neat accent somewhere in the yard.
    8200 gallon 20' x 48" round vinyl frame pool,
    Intex SWCG, 12" sand filter, 1600gph pump, TF100 test kit
    Mar 2007
    Morris, IL
    477
    I think that they are going to have to bring in a bigger digger just to drag them out of the ground in one piece. Or if you get a hoe ram and bust them up you could just get rid of them. Either way it is probably now time and material and I am sure it won't be cheap.
    steve
    Above Ground / 18' Round / Vinyl Liner / Sand Filter / 100K Gas Heater / Salt Added / No Nature2
    Quote Originally Posted by sevver
    I think they will be broken up ..... hopefully a few pieces bigger than a 3-5 sq feet will survive.
    The big machine coming in is a 12 foot wide, 30 ton unit ..... $2800 for the first 4 hours .... they don't expect it to go beyond the 4 hours.
    KC
    Quote Originally Posted by sredish
    I'm afraid a waterfall is not in our budget .... although after seeing many of the exceptional pools member's have shown here, it certainty is tempting. I don't even expect to take the interloc up to the pool edge. The pool will have the standard 2.5" cement surround framing the entire pool with the interloc tying the pool to the deck. I was going to talk to the cement guy to see what a stamped concrete surround and patio would run me though ($$$).
    Ok, so having said a waterfall is out, where would you all put it (position 1thru8) ????? Feel free to download the JPG and rough sketch your idea's .... and repost ...... who got me started on this !!!!
    4 or 5 would be my preference
    Mar 2007
    Ontario
    211
    In our quote for our pool they offered a diving board or a diving rock. He said a lot of people where starting to
    go for the rock look. When I drive by the builders yard you see the big pile of rocks they use.
    16x32 inground vinyl 8' deep end
    1hp Northstar Pump, 20" Sand Filter
    6ft Double Lounge, 2 Aqua Lamps w/remote
    216sqft Sungrabber Panels (9- 2'x12') a little undersized
    Quote Originally Posted by The Mermaid Queen
    Yes, still have visibility from the deck .... and room for laps without interfering. I think I'll start a thread as ask for pictures!
    KC
    Jul 2007
    North of Dallas
    207
    probably 4, nestled in that curve there would look very nice.
    Yes that location looks good. Talked to the installer yesterday ..... he will run the water up to that edge and cap it. I was talking to the team that does stamped concrete today .... i could have them do an couple of cement sonotubes in that area to carry any extra weight ..... this will leave me with the most options later if i do one.
    I just realized today that if i do a waterfall it will impact my winter cover .... which in itself is a several thousand dollar investment. So that means if i do a waterfall it will be a low profile, something the kids can walk over if they choose, and maybe even removable for the winter.
    Quote Originally Posted by kc
    ....... I was talking to the team that does stamped concrete today .... i could have them do an couple of cement sonotubes in that area to carry any extra weight ..... ....
    If we go with stamped it will be this pattern ,,,, right up to pool edge.
    KC
    This is the colour of the concrete ..... but under the flash and halogen lighting this colour is off ..... its really a taupe which matches the house color .... as opposed to the deck color which is a blue-gray.
    Jul 2007
    North of Dallas
    207
    if you have plans for any rock work there, make sure that you reinforce the concrete decking in that area to support the weight. typical concrete decking is a little thin weak to handle a fancy rock waterfall and you don't want any problems.
    Todays progress ....
    Todays progress .... wee rocks are gone ..... the resulting cavity now needs filling!
    KC
    Just about finished building up the wall on Thursday ..... where my $4000 rocks were.
  20. Back To Top    #20
    On Friday, the walls went up on top of the crushed stone base.....
