Thread: Intex floating skimmer with solar cover
    Jul 2012
    San Jose, CA
    13
    Has anyone used a solar cover with the Intex floating skimmer?
    I would presume I'd need to cut out a section of the cover to allow the skimmer to work.
    Or should I not use the skimmer if the solar cover is on?
    5000 gal, Intex 16'x48" above ground, Intex 2000gph cartridge filter w/SWG, TF100 Test Kit
    Re: Intex floating skimmer with solar cover
    I use the skimmer with my cover. I have to pull the cover up the bracket a little bit to keep it from getting sucked into the skimmer.
    18' x 48" Intex Ultra Frame
    2650 Intex Sand Filter
    Jun 2012
    MA
    347
    I can't see how the skimmer will work with a solar cover on. All the stuff that needs to be skimmed will be trapped by the cover. I do not use my skimmer with the cover on.
    Aug 2011
    Augusta, Kansas
    88
    noresull -what do you mean?
    Diane
    15,000 salty gallons - 24' x 12' x 52" Intex Ultra Frame Pool
    Intex Sand Filter, Pump, SWG - TF-100 and speed stir
    Quote Originally Posted by DianeF1
    Although it does not skim all the water, having the cover like in the picture allows the cover to not get sucked into the skimmer and thus some skimming will occur...
    [attachment=0:yscli047]ImageUploadedByTapatalk1344283459.724682.jpg[/attachment:yscli047]
