Thread: Can you help with timers
    Jul 2012
    CA
    240
    Hi, it tells you how to set the 3 hour filter run whe adding chemicals but how do you time it to go on at certain times like the analog intermatic timers.
    thanks
    sorry about the bad pic
    compool lx3800
    25k I/G ecostar ccplus Polaris plaster
    Apr 2011
    Lynchburg VA
    393
    Re: Can you help with timers
    Here is a link to the instruction manual. Page 31 has programming instructions.
    http://www.pentairpool.com/pdfs/cp3800OM.pdf
    18x36 Vinyl In-ground w/roman ends 27,400G, Hayward 3/4hp with 300# sand filter. Hayward heat pump heater
    Pool School
    Pool Calculator
    Test Kits
    Jul 2012
    CA
    240
    You da man! thanks!
