Page 1 of 2 12 LastLast
Results 1 to 20 of 29
Thread: AG Ladder Woes
    AG Ladder Woes
    So we're not liking our ladder situation that came with the new pool. Here's a pic of it:
    http://www.aboveground-swimming-pools.c ... adder.html
    The PB Screwed it directly onto our pool top railings. The ladder is floating (gotta put weights on it - but it's causing the top rail to bend as you can kinda see in the pic to the left of the ladder. I don't think it's the greatest idea to put that much weight on the pool edges all the time - what do you guys think?
    However - I've got 12" rails and a 56" deep pool so I probably need something extra special to reach around. I hear people seem pretty happy with this ladder:
    However - I don't know for sure if it's going to extend to 56" and if there's more then a foot between where it mounts to the deck and where it goes into the pool. Wondering if anyone else has this ladder and could get me those dimensions - would be a huge help.
    21' Round (12k Gallons) AG
    Strong Pools Colosseum Riser 56", 1 hp Sand filter, 10'x12' Composite Deck,
    Auquacal Aerotemp Heat Pump, Also: Sundance Cameo Spa
    See my pool build thread here: Katkami's Pool Build - With time lapse video!
    Mar 2007
    Texas
    444
    Katkami,
    I to had the ladder that you have, and the guy also bolted it right to the top rail, I didnt like that at all, but I didnt like the ladder any way, so I got the wedding cake steps, You may want to look into those, I am VERY glad I did.
    27' Round AG, 17,200 gallons, sand filter
    Mar 2007
    Richmond, Va
    179
    We have the Royal Entrance steps and love them! Yes, it takes up spacein the pool, but you can sit on the steps, and it just makes it so easy to get in or out regardless of age, shape or level of wine or beer consumed......seriously, it makes an AG feel like an IG.
    18 ft.52" Round Atrium AG -7600 gallons, Sand Filter, Vinyl liner, Royal Entrance Steps, 80 lbs.solarsalt
    Thanks guys - Royal entrance is probably not going to work for us it says "will fit either a 48” or 52” deep pool"
    Wedding cake steps - do those have to attach somewhere? Seems like they'd take a lot of real estate in our 21' pool. I heard some concerns about circulation & taking them out in the winter also....
    I found a wedding cake II manual:
    http://www.inyopools.com/owners_manual/lumio_ne100.pdf
    The brace doesn't look very long though (?)
    May 2008
    Austin, TX
    27
    I have the exact steps your looking at getting. There are 16" between the middle of the front pipe and the middle of the back one. My husband braced our deck from underneath with another 2x4 then drilled through both the deck board and 2x4 with a hole saw so the pipes go through both then under the deck. It's pretty sturdy but if you want a ladder that doesn't float this isn't it.
    We tried putting scuba weights in it (I think we were over 75 lbs) and it still floats, not a lot but it does. We have a mat on the bottom of our liner so it doesn't get chewed up.
    We have a 56" deep pool, the top step is only a couple inches below the water level
    12' x 28' Doughboy, partially underground, 9100 gal. Hayward pump and sand filter, Barracuda Zippy pressure side cleaner.
    Thanks JC - Sounds like the measurements are good, but drilling holes through our brand new deck is skeery and a big commitment for a ladder that still floats.
    Mar 2007
    Texas
    444
    On my weeding cake steps, the brace is long enough to go past the top rail and screw to the deck, as far as circulation, water does not circulate the best behind them, but I do like the instructions you posted said and put my water hose behind the steps when i have to add water. As far as getting them out at the end of the season, I take mine out by myself with no problems.
    NWMNMom's Avatar
    Waaay NW MN
    1,582
    We bought the Biltmore Drop-in Steps and are very glad we did. They have excellent flow through so no algae buildup issues to worry about. The ladder was too hard for my mother in law to go up and down
    18x33x52 Buttressfree Seaspray (Wilbar) AGP - 1.5hp Pentair Maxim w/22" Pentair Meteor Sand Filter, Aqua Rite SWG System, Biltmore Walk In Steps - 2/4x20 Solar Panel Setup - Doheny Jet Drive (RIP -Pool Rover Jr) - finally hard plumbed the whole darned thing -
    Beats Driving to the Lake!
    Mar 2007
    Texas
    444
    Quote Originally Posted by NWMNMom
    All the more reason to stay with the ladder
    frankthailand's Avatar
    Apr 2008
    Thailand
    152
    floating pool ladder
    is it the steps or the frame that is causing it to float, can you drill some small holes in it? [the frame orsteps] to let the water in so it doesn't float.
    Hello all from the land of smiles. Thailand. 5mx9mx1.5 63000L 16300 gall, pebbletex,
    pentair 1hp whisperflow, tagelus TA60 SF, swg monarch esc24 {a bit small for the tropics} 3 returns, 1 skimmer, 2 astral 100watt lights. Planned and built by me
    an AUSSIE expat living thailand for 18 years.
    Oct 2007
    Cedar Hill, TN
    252
    Where did you get them, and what do they look like?
    I don't like our steps, they are flimsy and it's hard to get out of the water by way of these steps. It's easier to just pull up and twist to sit on the edge in order to get out.
    My cleaner also gets stuck on the bottom step. I constantly have to check & untrapp the cleaner out of the corner.
    12500 AGP 2HP Sand filter
    Five years on BBB & loving it!
    Casey's Avatar
    SW PA
    10,457
    I love our wedding cake steps but I have the room for it too... 24'. I bought it for my dd who was small at the time so she could play on the steps and now, I play on the steps.
    Good luck in your search.
    Quote Originally Posted by Poolidiot
    My top rail is 12", plus an inch or so of a gap before my deck starts - I'd need probably about 16" before I could safely screw it into the deck - would you say it's that long?
    Mar 2007
    Texas
    444
    I will measure it when I get home tonight and let you know
    Oh thanks, I'd really appreciate that!
    Mar 2007
    Texas
    444
    Ok, the brace measures 17" from the back of the hand rail to the tip of the brace, or 15 1/2" from the back of the rail to the center of the furtherest screw hole.
    I have this same ladder and like it. But we screw it into the deck and not the top rail. If you completely fill it with water properly it should not float. The steps and sides have holes for filling with water. Your PB probably got impatient waiting for it to fill.
    Sue
    Current Pool: IG Concrete / 11,000 gal. / Sand filter / Solar heat / Hayward CL200 / Screened / TF Testkit
    Pool owner since 2001. Thanks TFP for helping me convert off Baquacil after six years!
    Woah I had no idea there were holes that were supposed to be filled with water. We'll have to check that out. Plus there were a bunch of extra parts he left - I wonder if I can somehow use those to fasten it to the deck (if it will reach). Grrr - yeah - he was in a rush to leave and we reminded him he didn't do the ladder yet and he threw it on so I wouldn't doubt that he rushed it and did it wrong.
    Thanks for the brace measurements as well - looks like we might be able to handle the cake steps (if it can be extended to our 56" depth). Those would be a nice upgrade
  20. Back To Top    #20
    Casey's Avatar
    SW PA
    10,457
    I went out and snapped some pics for ya and even checked the total heigth alotted for the wedding cake steps. Looks like you're in luck... I can measure up to 61"
    My steps are a little dirty right now. Okay! Alot dirty!
    Here is how I have mine attached to deck... From that curve where it would go over top rail and onto decking, you'll have 16" first screw is 6" in.
    Please note that these steps do need weighted down. I made my own weights about 5 years ago by filling ziplock bags and wrapping them with packaging tape and then duct tape. They do leak a bit of sand though but not bad for a red neck.
