Thread: Hi-Flo 1 1/2 HP 2 speed 48 frame pump impeller (PH2150)
    67ragtop's Avatar
    Mar 2012
    Tampa, FLA
    12
    Anyone know if these are pressed on or screwed on? It appears that the seal on my 2 month old pump went bad already......
    33" Oxford Aluminum AGP, Hayward Aqua-Rite SWG with T-15 cell, Clearwater 150 Sq. Ft. cartridge filter with 2-speed 1.5 hp pump
    Re: Hi-Flo 1 1/2 HP 2 speed 48 frame pump impeller (PH2150)
    Impellers almost invariably screw on.
    67ragtop's Avatar
    Mar 2012
    Tampa, FLA
    12
    Thanks...will give it a go. This one is recessed in the housing. Any tips for removal?
    Here's the schematic:
    http://www.aqua-man.com/schematic.asp?kc=S1681&s=full
    We have a good walk through for replacing the pump seals here. That is for a different brand of pump, but it covers many of the same steps and the pumps should be at least mostly similar.
    67ragtop's Avatar
    Mar 2012
    Tampa, FLA
    12
    Thanks for the link and the replies Jason.
    Shawn
