View Poll Results: How do you sanitize/balance your pool water?
Voters
26. You may not vote on this poll
  • BBB method?
    19 73.08%
  • (TIC)Toss in chems method?
    1 3.85%
  • SWCG
    6 23.08%
Results 1 to 8 of 8
Thread: Treating water~ How do you do it?
    lulupalooza's Avatar
    Mar 2008
    Evans, GA
    323
    Just doing a little poll here to see what the consensus is
    *~ Laura ~*
    27x52 Aquasphere Conquest AGP (approx.17,100 gal)
    1 HP Pentair Dynamo Pump & SD-40 Sand Filter
    TF-100 Test Kit
    BBB User- Salt Added
    Jul 2007
    Sahuarita, AZ
    278
    I'd say you're short on a few options... I for one use a SWCG so I don't really qualify as BBB nor do I TIC. Plus there are more than a few that use the pool-store guidance and chemicals (or is that what you consider TIC?)
    My Pool:
    12K gal IG gunite with 7' raised spa, gunite waterfall, PebbleTec Caribbean Blue finish, solar heating & in-floor cleaning system
    Equipment: Sta-Rite 300' Cartridge Filter, Intellichlor IC20 SWCG, Sta-Rite 400k BTU heater, Intelliflow 4x160 main pump & Sta-Rite 3/4 hp waterfall pump, EasyTouch controlls w/ wireless controller, TF-100 Test Kit w/ salt test.
    Guest
    Lulupalooza, if you are referring to whether people test their water to determine what and how much they need or just dump stuff in their pools and hope for the best I think you will find that most of our members (if not all) do the former since, no matter HOW you are sanitizing your pool it is the proper way to do it (even if you are using trichlor tabs and bags of shock).
    Jul 2007
    North of Dallas
    207
    salt...
    My Pool - 18x24 fully setup Cabana, 22x48 gunite/quartz plaster (3-5-3 depth) & 8' spa w/ spill and 5' natural rock waterfall; Hayward DE filter/pumps/heater; Hayward Pro Logic controller; Phantom cleaner. Finished 06/01/07.
    RedishConstruction.com
    Mar 2008
    Evans, GA
    323
    Actually should have rephrased it a little diffrently, but since it wouldn't let me edit the post, oh well.
    I was just curious to see how many uses the bbb method or the TIC(pool store chems, like shock, triclor, etc.)
    Forgot to add those who use SWCG
    I figured that most people use the pool store stuff. I am actually quite surprised to see that a lot use the BBB method.
    *~ Laura ~*
    TF-100 Test Kit
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Edited
    Guest
    BBB ARE pool store chems, they just have other names for them like liquid chlorine for the bleach, Optimizer, Supreme, and Endure for the borax, and alkalinity increaser for the baking soda. There is no magic or method to BBB other than knowing WHAT chemical you need to add, HOW MUCH to add, and WHEN to add it. This is determined by water testing with a good test kit. Those 'pool store chems' you refer to ARE used in the BBB method. There is a place for trichor (great with new plaster pools) and cal hypo (commonly sold as shock) in pool maintenance when used properly.
    Bottom line is that a pool can be properly maintained with pool store chemicals and badly maintained by BBB. Like I said, proper testing and dosing is the difference. Ditto for SWGs.
