Results 1 to 7 of 7
Thread: New and No FC
    Makdaddy's Avatar
    Jul 2012
    Springfield Illinois
    119
    New and No FC
    Ok Im learning as I go
    apparently the hard way
    AGP 24 Round 54 tall 15200 Gallon
    We filled the pool from the tap took a day
    I am using salt
    added 320 ponds of salt
    I am using a Saltron Retro
    I have green light for good salt level.set to run 20 hrs a day for now
    I ordered the TF-100
    So the SWG is running I see the smokey exhaust
    Water is super clear
    I get my kit and check FC and PH
    FC=0
    PH=8.2
    I figure i need to add Chlorine, I do some more research and check the Pool Calculator
    According to it I need to add 168 oz of 6% Bleach
    I get that at Walmart I add 182 oz
    Today I check again and also check for CYA, after doing more research
    FC=0
    PH8.2
    CYA=0
    SWG still running 20 hrs a day Pool still clear
    Im confused how the CF still equals Zero
    So tonight I added Smart Liquid shock 1 gallon and 6 oz of HTH #2 it says Trichloro in a floating container
    I think if I did my home work that the HTH will bring up my CYA
    I bet I will still need to add a conditioner to bring it up to 60 or 80
    But the store was out, I hope my wife gets it at lunch tomorrow.
    I will run all of the tests tomorrow after work
    I am sure that once everything is balanced the SWG will work just fine, and I should check Cf every couple of days.
    What else am I missing? I will run all of the other tests after I get the CF-PH-CYA all set, I just didn't want to get to overwhelmed and I am already it appears
    No pool use as of yet I hope to have everything squared away for this weekend
    --- Greg----
    24 x 54 Round Cozumel AGP with Grand Entrance Step 14500 Gal
    Running ntex Krystal Clear Saltwater System with E.C.O.
    A/G Cristal Flo II Sand Filter Tank w/ 2HP, 2-Speed Dynamo pump -Zeobest
    TFT Test Kit---Gorilla Floor and Foam Pool Cove--Half Deck
    Re: New and No CF
    When CYA is zero, you lose chlorine very quickly to sunlight. You should raise CYA/stabilizer/conditioner to around 40 to 50 for now, and then raise it further later. You don't want to add too much CYA at one time, as lowering the level is difficult. Safer to raise it a bit right now, and then more later instead of risking adding too much.
    You need to bring your PH down. You never want to let PH get above 8.0. Since the PH test only goes up to 8.2, your actual PH might be much higher.
    Makdaddy's Avatar
    Jul 2012
    119
    Re: New and No CF
    Thanks Jason
    Ill head that advice as I bring up the CYA
    I hope I see some CF Level in my test tomorrow night
    Greg
    --- Greg----
    UnderWaterVanya's Avatar
    Jun 2012
    Mint Hill, NC
    2,589
    Re: New and No CF
    What is CF? Do you mean FC?
    Makdaddy's Avatar
    Jul 2012
    119
    Re: New and No CF
    Quote Originally Posted by UnderWaterVanya
    Yes Sorry its late
    --- Greg----
    frogabog's Avatar
    Jul 2010
    Portland, Oregon
    1,578
    Re: New and No CF
    Do you have any muriatic or dry acid to use to lower pH? That should be done right away. Shoot for around 7.2, and the pH will likely rise again due to the SWG.
    The trichlor tablet you added is acidic and will also lower pH a little, so make sure to test pH before you lower it. Additionally, when you calculate your CYA, take into account the weight of all the trichlor tablets you've used and deduct that from the amount of CYA you add.
    At the bottom of the Pool Calculator you will see a field where you can enter in values of chemicals and pull up a result of all the effects it will have on your pool water. I can't remember the weight of a 3" tablet but I believe it's somewhere around 7oz. I hope someone will correct me if that's wrong. You can weigh the tablet of course and I know it's been discussed here on the forum (search).
    Where kids swim in 54 degree water, turn blue, and giggle happily cuz they got a POOL!
    Year 3 BBB -15' x 48" Intex Metal Frame - Was using (2) 1000gph Intex cartridge filters (see Full time pumping Intex). 2012, converted to 1600gph and sand filter+SWG = Sand filter love affair!
    Don't waste time and energy looking for a better value on test kits, the TF100 is the best deal around. I did the looking and spent the extra money, but you don't have to make the same mistake. Just go here: TFTestkits. I use Pool Calculator for min/max, and shocking chlorine levels.
    Makdaddy's Avatar
    Jul 2012
    119
    Re: New and No FC
    OK we added Cyanuric Acid
    My levels look much better
    FC= 3
    PH= 7.5
    CYA=30
    Will be adding more Cyanuric Acid to get better CYA
    Thanks for all the help
    --- Greg----
