Thread: no bubbles
    no bubbles
    pentair pump does not seem to have much pressure and no bubbles when spa turned on. Pump need replaced?
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,056
    Re: no bubbles
    I'd look more for restricted flow. A valve in the wrong position. A clogged filter - gauges frequently go bad. Maybe a wad of leaves in the strainer or clogging the impeller. We really need more information. pool-school/read_before_you_post
