Thread: Help balancing
    Help balancing
    I give up trying to balance on my own. Any help would be appreciated.
    FC=3
    Ph=7.6
    TA=250
    CH=200
    CYA=50
    I put 4lbs of stabilizer in yesterday.
    Northern Michigan, 24'x52" AGP, Intex 2500gph filter, Krystal Clear SWG, Taylor K-2006,
    30,432
    Re: Help balancing
    Well, those numbers don't look all that bad.....how does your water look?
    38,521
    Re: Help balancing
    From memory, isn't a FC of 3ppm the absolute minimum required for a CYA of 50ppm? Definitely want to keep the FC a bit higher to have some buffer room.
    Posted from my Droid with Tapatalk ... sorry if my response is short
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,067
    Re: Help balancing
    He has a SWG, so he gets to maintain it lower.
    Vette's Avatar
    Jul 2012
    Ohio
    404
    Re: Help balancing
    Remember that your stabilizer won't show up in tests for about a week.
    11,700 gallon 21' round 54" deep all-resin AGP - June 2012
    Waterway 1HP 2-speed pump / 100 sq ft cartridge filter
    Hayward 150,000btu Natural Gas heater
    I use and recommend the TF-100 for testing
    38,521
    Re: Help balancing
    Quote Originally Posted by Richard320
    Oops ... the lack of signatures on my phone strikes again.
