Thread: Solar heat drilling valves??
    Isaac-1's Avatar
    SW Louisiana
    6,711
    In some message threads I have read reference to needing special types of valves for use with solar panels or drilling holes in valves. Can someone explain what this is about?
    thanks
    Ike
    38,371
    Re: Solar heat drilling valves??
    If it is desired to have the panels drain when the pump and solar valve turns off, the water needs a path back down the solar source lines which usually feed the bottom of the panels. One method is to drill a small hole in the valve diverter.
    Pentair sells a solar valve that has a small check valve built into the diverter. This allows the water to flow back down when the valve is closed, but does not let water get pushed back up if there is no call for solar when the pump is on.
    The hole drill method would allow a little water flow up toward the solar even if the solar valve was closed.
    Posted with Tapatalk ... sorry if I sound short ... hate typing on phone
