Thread: Feeder Leak
    Feeder Leak
    Please see the attached picture. Is it fixable? or should I just permanently close the connection to the feeder? I'm also asking for advise on how to best permanently close/seal the pvc.
    Thank you
    Jovian, Pool owner since 2011
    Specs: 30k Gallons, Sand Filter, IG, Vinyl, Filter: Hayward S244T, Pump: Hayward 1.5 HP SP2610X15
    22,550
    Re: Feeder Leak
    Most people just take and connect one of the hoses from the inlet connection to the outlet connection, effectively bypassing the feeder and sealing off the holes.
    Re: Feeder Leak
    Thank you for the reply. But doesn't that mean some water will bypass the filter?
    Re: Feeder Leak
    also I still kinda want to use the feeder. I'm a BBB enthusiast, but I think it's still nice to have the option of using Chlorine Tab when appropriate.
    22,550
    Re: Feeder Leak
    Some water does pass thru the tubing but it's a small amount. It's hard to tell from the pic exactly where the leak is.
    CUTiger78's Avatar
    May 2009
    NoVA
    460
    Re: Feeder Leak
    If the leak is coming from the lid, you can buy a replacement gasket. I have had to do that more than once.
    36K gallon 42X22 gunite/plaster kidney-shaped IG;
    1 hp Hayward Super Pump (new in 2012);
    Hayward S244T sand filter w/ Zeosand (both new in 2009);
    175K BTU LAARS Lite2 LG natural gas heater; Polaris 380;
    TF-100 test kit.
