Thread: Pump Timer
    Pump Timer
    Does anyone know what can be used for the intex 110v pumps to control the timing of turning off and on??
    I am putting in a dedicated gfi for the pump and was wondering what could be done
    thanks
    Hicksville, NY
    1950 Gallon Summer Escape 12' x 36" Round
    Above Ground Vinyl Pool
    Intex Krystal Clear 1,600 Gallon Sand Filter
    cramar's Avatar
    Nov 2010
    Sault Ontario
    1,143
    Re: Pump Timer
    You can hard wire a timer, not sure if your set up accommodates that, or you can buy a heavy duty spa/pool timer from a big box store. Pump plugs into that and that plugs into your gfci, they should specify pool/spa grade.
    I suspect many brands are cheap though, I bought a Noma timer up here north of the border and it's garbage, it actually runs backwards now.
    Re: Pump Timer
    i would prefer not to use one that plugs inline for safety reasons
    Hicksville, NY
    Jun 2012
    Glen Burnie, MD
    38
    Re: Pump Timer
    I use a timer that I bought around X-Mas time, during the winter I will use them for my lights. It is a simple plug in timer and works great.
    8000 Gallon 18' Round 52" Deep Morada Pool (Namco) DE Filter
