Thread: Newbie
    Newbie
    Is chlorine stabilizer the same as dichlor? What exactly is that?
    Vette's Avatar
    Jul 2012
    Ohio
    404
    Re: Newbie
    Stabilizer is a fancy name for Cyanuric acid. Dichlor is a form of chlorine, usually powdered I believe. Trichlor is the tabs/pucks. So no, not the same, although Cyanuric Acid works to protect the chlorine from the sun.
    And Welcome to TFP!!! We are here if you have any other questions!
    11,700 gallon 21' round 54" deep all-resin AGP - June 2012
    Waterway 1HP 2-speed pump / 100 sq ft cartridge filter
    Hayward 150,000btu Natural Gas heater
    I use and recommend the TF-100 for testing
    UnderWaterVanya's Avatar
    Jun 2012
    Mint Hill, NC
    2,589
    Re: Newbie
    Quote Originally Posted by huckle23
    CYA is the stabilizer you are talking about. DiChlor and TriChlor both contain CYA. Read up on this in Pool School in the ABC's of Water Chemistry.
