Thread: Leave Polaris 280 in pool 24X7?
    Hi,
    I finally got my Polaris to work. Now my question is should I leave it in pool 24X7 or take it out when it's done.
    elwood58's Avatar
    May 2012
    Sun City West Arizona (2nd Home)
    653
    Re: Leave Polaris 280 in pool 24X7?
    Most people take it out of the pool so it is not in the way while swimming. If you do take it out, get it out of the sun and away from other things that might damage it. It will not hurt it to leave it in the water, but sitting deck side, it will deteriorate before your eyes.
    19204 Gallon L Shape with a 10X10 2nd Step Baja Ledge. Intellichlor IC-40, IntellipH, Cartridge Filter, Pentair Heater/Chiller (Heat Pump). Tons of Deck with Deck Jets. Construction Complete 6/5/17.
    "If you don't measure it, you can't manage it!"
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    ustcer90:
    I take my Polaris 360 out of the pool when I'm not using it and store it in a shed.
    Not sure where you live, but here in DFW I keep the pool operational year-round even though it's too cold to swim in for 4-5 months out of the year. During the winter, I manually fish out whatever falls to the bottom and use the Polaris only if absolutely necessary. The first year I was in this house, I left it in the pool all winter based on advice of friends/co-workers. Around mid-late February of that year, it started malfunctioning. Part of the cause was hoses and seals and part of it was devices within the unit itself. Pool store near me (which is rather reputable compared to some of the pool store stories others have posted) mentioned that the colder water tends to make parts more brittle and susceptible to breakage. That seems to have merit in my case. This past winter, I used it only 2-3 times during the off season with no problems and avoided the previous year's hefty repair bill. So that advice seems to have worked well for me.
    One other related bit of advice: The bag is much easier to empty if you let it dry completely first. On mine, I disconnect the bag from the unit, store the unit in the shed, and leave the bag in the sun for a few hours or so to dry. Then I empty it and reattach it to the unit so it's ready for the next use.
    Nov 2010
    Calera, Al
    271
    I leave ours in the pool and only remove it when we are using the pool. I also have our pool open year round. I used to run it daily but now I run it as needed or every few days. It has been in the pool now for 1.5 years with no I'll effects. I have replaced the tail scrubbers and purchased a new bag, but from what I understand that is pretty routine.
    17,000 gal, IG Gunite Diamond Brite plaster Kidneybean,w/7x11 tanning ledge& 3x5 swimout bench,244T 300lb Hayward Pro high rate sand filter(63 GPM) , Hayward 1Hp Super Pump w/3/4 hp booster pump, Polaris 280, Laars Lite 2 175k N/G Heater, Tf-100, Speed stir
    CUTiger78's Avatar
    May 2009
    NoVA
    460
    I leave my 380 in the pool 24/7. It goes into the shed during the off season.
    BTW, ditto to Bo's comment on how well a Polaris works in cold water. In my experience, it doesn't work well until the water temp gets to 70 and higher.
    36K gallon 42X22 gunite/plaster kidney-shaped IG;
    1 hp Hayward Super Pump (new in 2012);
    Hayward S244T sand filter w/ Zeosand (both new in 2009);
    175K BTU LAARS Lite2 LG natural gas heater; Polaris 380;
    TF-100 test kit.
